RE: Front bearing Leakage
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. BGX-1 3500 w/ BCM #4224 Pitt
Seller:  jmhernan
Details:   $200.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Front bearing Leakage
Page: <<   < prev  1 [2]
Login
RE: Front bearing Leakage - 4/29/2008 8:41:38 PM
jaka
Status: offline
Hi!
So remove the head shim! It is only there to have a proper timing! Has nothing to do with sealing at all.
_____________________________
Jan Karlsson Airracing products
MVVS, Motul "Micro" all synthetic oil
(in reply to estradajae)
       Post #: 26
RE: Front bearing Leakage - 4/29/2008 9:24:05 PM
XJet
Status: offline
A low compression ratio will not cause the engine to run fine and then suddenly stop.
Such symptoms almost always boil down to fuel, fuel system or glowplug.
Something is putting the fire out and that's either a loss of plug heat (which may be gradual due to an inadequate catalytic effect brought about by stale fuel or a weak plug) or the engine going lean through fuel restriction/air ingestion.
These aren't complex machines, just keep eliminating the possibilities and the cause will be whatever remains :-)
When I'm not here, I'm at RCModelReviews
(in reply to jaka)
       Post #: 27
RE: Front bearing Leakage - 4/29/2008 9:45:51 PM
estradajae
Status: offline
I'm agree with you Xjet. I wouldn't have said it better.
Í've checked carb, needle and everything is fine..perhaps the glow plug as you've said is not working anymore. Sometimes it's not easy to find how healthy is the plug, because it may looks nice but it may not be doing the job. I'll tell you when I got the chance to run the engine again, I'll change the plug and see what happens.
Thank you for your input.
Jorge
Airplanes, engines and flying become an addiction...with not enough wallet
(in reply to XJet)
       Post #: 28
RE: Front bearing Leakage - 4/29/2008 9:50:26 PM
Sport_Pilot
Status: offline
That is not the premise of my advise. I was commenting on the first post which said it would quit on a sudden throttle up or throttle chop.
“I Saw Elvis at 1000 Feet” John Force
       Post #: 29
RE: Front bearing Leakage - 4/29/2008 10:43:25 PM
estradajae
Status: offline
It was refered to Jaka's post.
Jorge
(in reply to Sport_Pilot)
       Post #: 30
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
