Need Help identifying and glueing plastics
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Need Help identifying and glueing plastics Page: [1]
Login
Need Help identifying and glueing plastics - 4/27/2008 4:46:14 AM
Mooney_driver
Status: offline
This may be a bit off topic but it does apply to models and model building as well as other things. I have often run into situations where I need to repair a plastic model or other plastic item but have not found any information to help me identify the type of plastic that needs to be repaired or the correct glue to repair the plastic. How do you find that information? I have often tried CA and epoxy only to find that they either cure on the surface or do nothing but make a mess. I have tried Acetone thinking it would weld/melt the plastic for form the repair but again no repair is made. As a last resort I use the acetone glues but since Acetone itself did not work the acetone based glues do not work either.
Can someone tell me how to identify the particular pastic and composites and the glue that might fix it?
Thank you.
       Post #: 1
RE: Need Help identifying and glueing plastics - 4/27/2008 2:40:38 PM
KC36330
Status: offline
if this 'plastic' is really acrylic then you don't use acetone you need weld-on. MEK would also work, but it's one of them nasty carcinogens.
(in reply to Mooney_driver)
       Post #: 2
RE: Need Help identifying and glueing plastics - 4/27/2008 8:18:22 PM
Mooney_driver
Status: offline
I have not been able to find Weld On around here as I have looked for Weld On #3 to weld plexiglass but no luck locally. MEK is or was still available at Ace Hardware so will try that.
My real question is how to first identify the type of plastic and then how to find out what will weld/glue/repair it?
Thank you for the info.
(in reply to KC36330)
       Post #: 3
RE: Need Help identifying and glueing plastics - 4/27/2008 9:05:46 PM
KC36330
Status: offline
there are just way too many products to give any sort of idea as to what you've got. on the #3 i get mien from Regal Plastics, they ship would wide too.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
