Covering plans
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Covering plans Page: [1]
Login
Covering plans - 4/27/2008 8:56:08 AM
slowglowflyer
Status: offline
What is the best thing to do with plans before you start building? Is there anything better than waxpaper to put over them to protect them?
Mike
       Post #: 1
RE: Covering plans - 4/27/2008 10:09:03 AM
grimmy55
Status: online
yep its clear vinyl over here its about $9.00 a metre but it will last for years doesn,t crease as clear as glass bloody brilliant
(in reply to slowglowflyer)
       Post #: 2
RE: Covering plans - 4/27/2008 1:53:06 PM
Walt Thyng
Status: offline
Last time I moved I snatched a roll of that stuff they use to wrap furniture. Works great. Probably the same stuff they use to secure pallet loads.
Walt
_____________________________
WT in Illinois
(in reply to grimmy55)
       Post #: 3
RE: Covering plans - 4/27/2008 9:58:14 PM
grimmy55
Status: online
The stuff here is vinyl same as car upholstery but its clear I think the stuff you are referring to is shrink wrap they put it round pallets for shipping it stretches heaps this stuff is very flexi and impossible to rip
(in reply to Walt Thyng)
       Post #: 4
RE: Covering plans - 4/27/2008 10:51:18 PM
Dorsal
Status: offline
Rubbermaid has rolls of Clear Contact Paper called "Clear Cover". It's an 18" wide roll, this one is 8 yards long. I think I bought this at WalMart.
I'm just about to cover a sheet of foamie plans to cut them up for templates.
       Post #: 5
RE: Covering plans - 4/28/2008 12:25:18 AM
slowglowflyer
Status: offline
Is this contact paper stickey on one side or something? Does it achieve the same things as wax paper? (No glue, clear, ect.)
(in reply to Dorsal)
       Post #: 6
RE: Covering plans - 4/28/2008 12:32:43 AM
Campy
Status: offline
Go to Wal-Mart and buy a 2 - 4 mil drop cloth (about $2.00 ). You will be able to cover several sets of plans with the drop cloth if you are reasonably careful in removing it when done (it not, it is cheap to replace). Unless you flood a joint (get a puddle under it), CA does not stick to it and alphetic glues (TiteBond) stick a little, but a flick of the fingernail usually removes about 99% of the drops.
The 2 mil is clearer than the 4 mil, however the 4 mil holds up better.
       Post #: 7
RE: Covering plans - 4/28/2008 11:43:35 AM
huggins
Status: offline
Actually, I have found the plastic wrap from the kitchen drawer works quite well. You have to pin or tape it down because it so thin, but glues do not stick to it. About anything, in my opinion, works better than wax paper. Wax paper was fine when we were build with Ambroid and carpenters glue but does not work very well with CA.
If you cover with Monokote, save the backing when you cover your wings. The backing works very well as a plan protector. Great Planes sells a product for protecting plans as well and have heard that it is the same stuff used for Monokote backing.
Mike
(in reply to Campy)
       Post #: 8
RE: Covering plans - 4/29/2008 4:14:26 AM
sebo
Status: offline
Press'n Seal works good too. It will stick to the plans but pulls up easily. I've used waxed paper for years but am really pleased that I ran out of it and had to use Press'n Seal (Made by GLAD). I'm going to keep using it. Ron
< Message edited by sebo -- 4/29/2008 4:16:58 AM >
(in reply to huggins)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
