perry carb for FOXES
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> perry carb for FOXES
Page: [1]
Login
perry carb for FOXES - 4/27/2008 3:49:48 PM
WhiteRook
Status: offline
was there ever a perry replacement carb for the fox engines? i think you need some kind of adapter to go with it
thanks RCU
       Post #: 1
RE: perry carb for FOXES - 4/27/2008 4:03:23 PM
rainedave
Status: online
Yes, and the adapters are still being sold. The second item from the bottom in these parts tables:
http://www.perrypumps.com/prod05.htm
David
(in reply to WhiteRook)
       Post #: 2
RE: perry carb for FOXES - 4/27/2008 4:09:04 PM
rcdude7
Status: offline
Yes, there has always been an adapter available for fit the perry carbs. The adapter is #VP-FA $14.95
Get it from here: http://www.perrypumps.com/prod01.htm
Mike
       Post #: 3
RE: perry carb for FOXES - 4/27/2008 5:56:25 PM
Charley
Status: offline
quote:
ORIGINAL: WhiteRook
thanks RCU
I doubt if it would run any better. Anybody ever try it?
CR
< Message edited by Charley -- 4/27/2008 5:57:06 PM >
_____________________________
Charley
ccrobins@ktc.com
       Post #: 4
RE: perry carb for FOXES - 4/28/2008 1:47:34 AM
proptop
Status: offline
I had a Tower .60 that was basically an Eagle with a Perry carb...(that was in the mid 70's )
Ran quite well...easy to adjust...no problems.
It's bad luck to be superstitious...
Revver Bro #77
(in reply to Charley)
       Post #: 5
RE: perry carb for FOXES - 4/28/2008 3:47:47 AM
turbo.gst
Status: online
Fox used to manufacture one as well. It was called a " D Flange Adaptor". I used a few on some Fox's and they work quite well. Its nice to know that the Perry adaptor is still available.
In our case, I used it on my Dad's Fox Eagle 3. He was having problems obtaining a consistent needle setting. It turns out that our original Mk X carb had a rough spot that would collect fuel deposits. You could take it apart and clean it and have pretty decent results temporarily. We decided to try the flange adaptor with a HB .61 carb. It worked great and made a extremely reliable engine out of the old Fox. We did lose 200 rpm off the top end, but since it was on a trainer, we gladly traded it for the reliability.
I had a few other Fox's with Mk X carbs that ran well with no issues at all.
turbo
(in reply to proptop)
       Post #: 6
RE: perry carb for FOXES - 4/28/2008 3:53:23 AM
dammitman
Status: offline
i have several of them and they work great. but then again i have no trouble running any fox engine with the stock carb.
       Post #: 7
RE: perry carb for FOXES - 4/28/2008 12:43:13 PM
dant-RCU
Status: offline
I have used the Perry Pump carb w/Perry Pump on a Fox .74 - ran just fine. I was given an older Fox .78 with a damaged carb. Replaced
the carb with a standard Perry and flew it for 3 years until this year. Ran just fine.
Like dammitman, I have several Fox engines and have no trouble running them with stock carbs (either the air bleed or Mark X).
My .02
Dan
Dan Taylor
American Turf Flyers, Inc.
       Post #: 8
RE: perry carb for FOXES - 4/28/2008 1:25:14 PM
Sport_Pilot
Status: offline
I had a Fox Eagle I Tower .60 that came with a Perry carb. It didn't run well, never could get it to idle well. Bought a used Fox engine that came with an extra Fox MKX carb so I put it on the old Fox .60 and now it runs great. Not saying that it won't run well with a Perry, but this was my experiance.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.750RCU1
