RE: GST 3rd gear clutch mod
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing Genesis Monster Truck - RTR - RTR
Seller:  solidgold5
Details:   $250.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing Support >> RE: GST 3rd gear clutch mod
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: GST 3rd gear clutch mod - 5/1/2008 3:54:46 PM
burningpoo
Status: offline
Glad to hear everything worked out great for you. I would like to see 3rd hit sooner myself, so when I get some extra money to fix any mess ups I do I'm going to give it a shot
I might try from the sides when I do mine, have to make sure I take pictures myself.
Do you know how much wieght you added? The slugs you made, did they just fit, or did you have to work them?
_____________________________
Taking unbroken toys aparts since 1981
(in reply to sparky 25)
       Post #: 26
RE: GST 3rd gear clutch mod - 5/1/2008 4:29:43 PM
sparky 25
Status: offline
< Message edited by sparky 25 -- 5/13/2008 7:40:05 PM >
(in reply to burningpoo)
       Post #: 27
RE: GST 3rd gear clutch mod - 5/1/2008 4:44:27 PM
burningpoo
Status: offline
good point, thanks
When ever I get around to it, I think I'm going to try and get the weight of the slug to post here.
If you could, come back after gallon has ran through your mod so we know how it's holding up.
I can't wait to try, but bell buddy first.
       Post #: 28
RE: GST 3rd gear clutch mod - 5/1/2008 4:51:33 PM
sparky 25
Status: offline
I think once i get some real fuel through it i`ll take it apart
and take a pic to see how its doing but for now its the perfect solution for me
       Post #: 29
RE: GST 3rd gear clutch mod - 5/1/2008 5:44:11 PM
The Real Dogman
Status: offline
I think putting weight on BOTH sides of the Center adjustment screw would perfect your mod, that way the centrifigual force is equal on both sides
I will do this too sometime soon, if the fancy strikes me...lol
My Wife Knows How Much It Really Costs And Still Loves(lets)Me!
Nemesis/Genesis/Matrix Arena/Wheely King Tuber/Axial AX
       Post #: 30
RE: GST 3rd gear clutch mod - 5/1/2008 9:12:17 PM
sparky 25
Status: offline
quote:
ORIGINAL: The Real Dogman
I`ll do that to even things up and i will put teflon on to strengthen things up
doesn`t really need it, but when ive time on my hands i may aswell
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to The Real Dogman)
       Post #: 31
RE: GST 3rd gear clutch mod - 5/1/2008 9:36:06 PM
forevernitro75
Status: offline
were do you get that teflon from?
My girlfriend supports my hobby!!! $$$$
       Post #: 32
RE: GST 3rd gear clutch mod - 5/1/2008 11:43:04 PM
sparky 25
Status: offline
I got a small sheet of 1mm teflon of ebay
(in reply to forevernitro75)
       Post #: 33
RE: GST 3rd gear clutch mod - 5/4/2008 9:49:57 PM
sparky 25
Status: offline
quote:
ORIGINAL: sparky 25
DISASTER after 3 tanks of fuel the clutch would just start slipping like mad in third
so after a call to the hobby shop for a new set of clutch shoes i set to it again
I bored 2x 5mm holes on the side of each clutch shoe,
i sanded one side of each shoe and stuck a piece of 1mm teflon to them making sure it was the side that faces out of the clutch bell
I then took a hardened steel 4mm hex wrench (for a bit more weight) and cut off 4x 8mm lengths from it
epoxied them in the 4 holes and trimmed off the extra epoxy with a hobby knife
built it all back togeather and set the adjustment on the clutch to 7.5 turns out
when i took the truck for its first run out it shifted excellent
I ran 3 tanks of fuel through it and the truck shifted consistantly and effort less each time,
i can not be happier with how my truck now runs, its great
I will post a video tomorrow
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by sparky 25 -- 5/4/2008 9:52:38 PM >
       Post #: 34
RE: GST 3rd gear clutch mod - 5/5/2008 3:54:56 AM
The Real Dogman
Status: offline
The epoxy contaminated the 3rd gear Clutch. Did you clean and sand the inside of the 3rd gear clutchbell before you reassembled it??
       Post #: 35
RE: GST 3rd gear clutch mod - 5/5/2008 11:24:27 AM
sparky 25
Status: offline
On seeing the new clutch against the old one i noticed that the center of the old clutch had grooves in it
this was due to the adjustment holes on the clutch bell having a burr which ate the center out of the shoes
i took my dremmel with a sanding wheel and removed the burrs
the drilling in from the top wasn`t the greatest idea i know
but i think ive got it just perfect now i can be in third gear in as little as 30ft i could lengthen this with adjustment
and the truck still pulls brilliant with longer run times due to less revs
       Post #: 36
RE: GST 3rd gear clutch mod - 5/6/2008 6:37:04 AM
forevernitro75
Status: offline
sparky when you did your second clutch mod did you drill holes all the way through the clutches?
       Post #: 37
RE: GST 3rd gear clutch mod - 5/6/2008 5:34:53 PM
sparky 25
Status: offline
Yea i drilled all the way through
       Post #: 38
RE: GST 3rd gear clutch mod - 5/7/2008 5:58:38 PM
burningpoo
Status: offline
What does everyone think...
Will JB Weld hold up as good as epoxy? It did hold a alternator mount on for 2 weeks untill my friend's brother sold his truck. But that was metal to metal, I'm not sure what these trucks use as a clutch shoe. Maybe I'll try anyway, not sure.
       Post #: 39
RE: GST 3rd gear clutch mod - 5/7/2008 6:04:44 PM
sparky 25
Status: offline
I think jb weld will work just fine,
also dont be afraid to cut up a 4mm hex wrench as i did for the weights
the stainless bolts i used previous were just a little light for the job
hope you have as much sucess as i`ve had with mine
im sure you`ll be really pleased once you`ve done the mod
