RICKSTUBBZ
TX, USA Status: offline
Have not been able to get back to the “Pro” since Friday. I forgot to mention in my last post—that I was able to use my tile cutting saw (and diamond type blade) to rip the 1/32 plywood stock. I was quite surprised. Had nothing to loose giving it a try. I actually had stopped by harbor freight and picked up a thin (high speed steel) saw blade to use but it did not fit. Anyway good FYI stuff. I am considering adding 1/4” or so to the nose to help prevent a tail heavy build. Lots of chances to move battery and radio equipment further back but the front of the plane will get pretty crowded very fast. Just thinking at this point. I’ll decide by the time I frame up the fuse. quote:
ORIGINAL: WacoNut Rick I think the gain in strength will outweigh the gain in weight, there should be minimal weight gain from the modification. I have often thought about building this kit, I will be watching Anthony Anthony, I agree the extra strength will be worth the weight and work. Also, just to add, I think this is a neat kit. Lots of possibilities. One can build it right off the plans per the book and have a nice bird or you can go do some bashing, to add a personal touch, with out throwing everything away. quote:
ORIGINAL: jjscott Does anyone know if anyone sells Balsa USA kits at a discount? A month or so ago there was an ebay seller in northern Wisconsin who was offering Balsa USA kits (a dealer, I believe, but not the company itself). I've searched completed items but can't find him. Back on subject Rick, you've got a nice build going. Jim Jim Other than occasional unbuilt kits turning up here or there, I have no idea were to find Balsa USA kits other than from them. They are still a good deal for your buck.
_____________________________
Rick, AMA 115812 WACO Brotherhood #75
