manks
ON, CANADA Status: offline
I would agree with the first response, take off the covering and take a good look at the damage. From my experience, there is always a bit more damage then you think once you take a really good hard look. Take the time, do it right and be sure the plane is airworthy. If you just tape over it, and there is significant damage, you could lose the plane due to structural failure. Take the extra hour to avoid the extra costs of a major crash. Also make sure you check all of the control surfaces, firewall ect, give the plane a really good check. I had a minor crash, looked like very little damage, when out a few days later, and lost all 4 hinges in my elevator - in flight. I was very lucky to get the plane back on to the ground with out destroying it. Again it will take 10 min, you will likely find nothing wrong, but it is always good to be sure.
