takzi
Joined: 5/19/2006 From: Hong Kong, HONG KONG Status: offline
quote:
ORIGINAL: astroboycp Okay got some question for you guys. I somehow find that engaging 1st gear, my truck have problem moving. Running on 2nd and 3rd have no problem. Whenever I engage 1st gear, something seems to be stuck somewhere and the truck can't really move forward and after a short while, it surges forward. When I put the truck on its side, 1st gear engages nicely and the wheels turn smoothly. However, when it's on the ground, the problem surfaced. I've looked through but nothing is obstructing it so couldn't really pinpoint the problem. However, if I move the trim to the extreme left, it moves smoothly on 1st gear. I find it really strange. Has it happen to anyone before? You need a longer servo horn to fix your problem. The longer the horn, will help the rod to push in further into the gearbox to make the gear change. Try it out and see if it shifts smoothly. We all change to long servo horn on the first day (but mind you dont be too excessive in selecting the hron length, as it will burn the servo when the rod cannot be pushed in anymore.)
