Vacuum infusion or bagging?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Vacuum infusion or bagging? Page: [1]
Login
Vacuum infusion or bagging? - 4/28/2008 5:00:16 PM
Hatty
Status: offline
We are working on vacuum bagging a large body panel with a foam core from a foam male mold What would be the best method to use: vacuum bagging or vacuum infusion? What's the pros and cons of both?
_____________________________
University of Kentucky Solar Car Team
www.UKsolarcar.com
       Post #: 1
RE: Vacuum infusion or bagging? - 4/28/2008 8:50:11 PM
TeamSeacats
Status: online
In all likely hood, vacuum bagging will be your method of choice. It requires less planning and a few less materials and has less opportunities for catastrophic failures.
Resin infusion is the same as vacuum bagging except that you have to plan for the proper flow of the resin once you have pulled a vacuum. This requires proper placement of infusion ports, vacuum ports, and resin highways. Without a lot of planning, experience, and/or simulation software, getting this right the first couple of times is a rare occurrence. The benefits of resin infusion is less release of volatile fumes, better air evacuation from the laminate, and the ability to reposition the dry fabrics and reinforcements after the first vacuum is pulled.
With vacuum bagging a pre-wetted lamination, you can guarantee that you achieve proper resin saturation. With the proper peel-ply's / breather plys, you can achieve similar air evacuation.
Jake Kohl
http://www.teamseacats.com
(in reply to Hatty)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
3.859RCU1
