carb on os 70
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> carb on os 70
Page: [1]
Login
carb on os 70 - 3/11/2002 8:37:56 AM
daren
Status: offline
I have a os70 thats not running right. I took the carb off and stripped it down. I found the brass tube thats pressed in the carb case has a slit in it.its the tube that you see when you look down the throat of the carb. do you think thats causing my problem.
       Post #: 1
carb on os 70 - 3/11/2002 4:51:50 PM
jaka
Status: offline
Hello!
Nearly all OS engine carbs has a slit in their carbs(for fuel). So yours are perfectly normal..
If you hav etrouble with your engine...have you tried a OS F glowplug!?
Fuel: 5-15% nitro, 18-20% castor oil(or syntetic oil)the rest methanol.
Propeller: Always APC (because they are the best).
12x6,13x4,13x5,14x4 or 14x6.
Open the fuelneedle apr 2-2,5 turns from bottom and start the engine with the throttle drum open just 1,5-2mm. Use a glowdriver, so that the glowplug is glowing bright orange ornearly white.
Use a 12v batteri of atleast 7Ah preferable 10Ah.
Best of luck!
Regards!
Jan K
Sweden
_____________________________
Jan Karlsson Airracing products
MVVS, Motul "Micro" all synthetic oil
(in reply to daren)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.203RCU1
