HighPlains
KS, USA Status: offline
Cap, the 91 FS should be a great match with the light weight. I don't think it is possible to overpower the Acro-star as it is about the most overbuilt model I have ever seen. I turned a 13" diameter prop on mine, and it needed all the right thrust shown on the plans. With the CG towards the rear of the range, this airplane will tumble end over end better than anything else I have ever flown or seen flown, yet is a ****cat for landing. I started out with a 60, moved up to a 75 2c engine. My next one will be .90 powered.
_____________________________
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
