Toad
UT, USA Status: offline
For me, when I built my own engine, it was to keep the fuel line on the left side of the engine , on top when side mounted so the side exhaust didnt heat the fuel in the line going to the venturi and the fuel line is more convenient to get to, a side benifit is the intake window on the crank, it is more directly opposite the counter weight, that helps in the balance, the engine runs smoother, hence some rpm gain is the result. Of course on landing, it is also less prone to get dirt in the venturi if you mount the engine on it's side. On my latest engine, I am putting in a pressure nipple on the left side also, so tank filling will be easier and I wont have to use a bladder or run the pressure from the back plate where the vent line is harder to deal with. I like the idea, makes things way user friendly.
< Message edited by Toad -- 5/17/2008 6:43:00 AM >
_____________________________
speak 1/2a ?
