Toad
UT, USA Status: offline
I would probably forget to return it...accidently Here is what I plan on doing Nelson Plugs, 40% with all castor fuel, same actual propeller used on each, tach used will be TNC, I will run them within the same hr If I can. Engines to be compared will be my best VA, best modified AME .049, and .061. Cyclon .061, GZ .049 and .061, and the Profi .049 Not really fair to compare the .049's with the .061's other than it should be interesting. I cant do it this weekend. but the next. THis will require me to change mounts and stuff, Im gonna be busy. I will try to get pictures of the tach numbers. If I have my own engine ready by then I will throw that in. (version 3 casing # 8) I'll post the info on my site, it needs a revamp anyway.
_____________________________
speak 1/2a ?
