RE: aileron adjustment?
Tower Hobbies
Logged in as Guest
  Printable Version
Great Planes Venus 40 - RTF
Seller:  jigeye
Details:   $325.00   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> RE: aileron adjustment?
Page: <<   < prev  1 [2]
Login
RE: aileron adjustment? - 5/17/2008 4:03:55 AM
Montague
Status: offline
quote:
What's that? Holding slight up elevator while you taxi or something?
No, more involved than that. On a trike, you hold full up elevator from the start. Get the nosewheel off the ground, then relax the elevator slightly, keeping the nosewheel off the ground, but not lifting off quite yet. Let the plane speed up slightly, then pop the elevator again to get the mains off, followed by very quick down elevator to level off just above the ground, in "ground effect". You're not at flying speed yet, but you can do it in ground effect. Then you stay in ground effect until you accelerate up to normal lift off speed, and fly away.
On a tail dragger, there are less steps, but it's tricker because you basically horse it off the ground with the elevator really early, before you have flying speed. But then get the nose down quickly to stay in ground effect. You don't have the nosewheel to guide you. If you hold the up elevator too long, you get out of ground effect and get into a stall.
_____________________________
Kirk Montague Adams
RCCA 560
(in reply to gaRCfield)
       Post #: 26
RE: aileron adjustment? - 5/17/2008 4:08:43 AM
Charlie P.
Status: offline
A very handy thing to know about raising or lowering the ailerons together is that lowering them has the effect of increasing the angle of attack of the wing and raising them has the effect of decreasing the angle of attack. This is super handy in trimming out models for proper flight and especially handy in getting biplanes to fly well.
You can get a model to fly level at the desied thottle setting with the elevator, but it may squat. Lowering the ailerons a turn or two on the clevises (clevii?) could then get it back to flying with a nice horizontal center axis and reducing the overall drag.
Charlie P.
"Gravity is weak but it is persistant" AMA 747089/IMAA 30723
Oh Lord, your earth is so hard and my planes are so frail.
       Post #: 27
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
