Lomcevak Duck
GA, USA Status: offline
The Mojo is a very easy build. If you've done any other kit, you can build the Mojo. I built my Mojo .40 in three days. Just open the box, pour in some CA and shake. The 02-55 will be a laser cut short kit. Balsa sheeted foam core fuse. I have a kit ordered, and I'll take some pictures when it arrives. I did not build the 02-55 I own, it was one of the prototypes. Paul Swanson built part of this plane, maybe he can chime in with how the build was.
_____________________________
When someone loses a plane in the pits, you do a lomcevak duck. Press Alt F4 to see my other witty line.
