RE: Great Planes Cherokee ARF
Tower Hobbies
Logged in as Guest
Users viewing this topic: BountyHunter51
  Printable Version
1/6.5 Scale Fei Bao L-39 Albatros - ARF
Seller:  rcjetmodels
Details:   $1,080.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Great Planes Cherokee ARF
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Great Planes Cherokee ARF - 5/12/2008 4:20:39 AM
*JCB*
Status: offline
4000686798:
Would you kindly give a measurement of the width of the fuse just fore and aft of the wing? I am going to get some aluminum landing gear to mount the floats and i need these measurements to buy the best-fitting set.
Thanks!!!
_____________________________
"If your head is wax, don't walk in the sun." - B. Franklin
(in reply to 4000686798)
       Post #: 26
RE: Great Planes Cherokee ARF - 5/12/2008 6:49:36 PM
4000686798
Status: offline
The measurements are about 4-7/8 inches edge to edge. There is about a 1/2 inch radius up front, and 1/8 to 3/16 in back. Hope this helps please check the pictures. I also included two pictures of the area inside in front/behind the wing for hardwood mounts.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to *JCB*)
       Post #: 27
RE: Great Planes Cherokee ARF - 5/12/2008 8:33:10 PM
*JCB*
Status: offline
PERFECT!! thank you so much!!
What are those two hard-wood blocks on forward side of the wing, just inside of the wing dowel holes??
       Post #: 28
RE: Great Planes Cherokee ARF - 5/12/2008 8:45:08 PM
4000686798
Status: offline
Those are for the screws that hold the fuel tank floor in place.
Or if your going electric the motor battery floor.
(in reply to *JCB*)
       Post #: 29
RE: Great Planes Cherokee ARF - 5/14/2008 2:06:34 AM
sevans16
Status: offline
I just picked mine up at my LHS last saturday. I am going to put the OS 56FS-a in her. I am hoping to have her flying this coming Sun. Though it has been windy around here the last few days.
AMA# 737516
       Post #: 30
RE: Great Planes Cherokee ARF - 5/14/2008 2:29:40 AM
*JCB*
Status: offline
Finished the floats, now i just need the plane!! Each float weighs 14oz and installation takes about 6oz of hardware. So AUW of the floats is going to be about 2lbs and some change...
sevans16: have you run that motor yet? If so, how do you like it? I would have a hard time justifying paying that much money for an engine if it didn't perform all that well. For that price a YS 63 could be had, which is a real monster of an engine. I have seen the OS 56 in person and wasn't terribly impressed...
Click for fullsize
Click for fullsize
(in reply to sevans16)
       Post #: 31
RE: Great Planes Cherokee ARF - 5/14/2008 3:49:12 AM
sevans16
Status: offline
No I have not run it. I just bought it with the plane. I already have two of the 81's for my TF B-25 arf. So I figured what the hey. I have always been an OS man. I am always willing to try out the new stuff.
AMA# 737516
(in reply to *JCB*)
       Post #: 32
RE: Great Planes Cherokee ARF - 5/14/2008 4:42:20 AM
*JCB*
Status: offline
you are a better man than I!! The only loyalty I have is to my pocketbook (for the most part)
       Post #: 33
RE: Great Planes Cherokee ARF - 5/20/2008 1:42:11 AM
*JCB*
Status: offline
Has anybody flown this thing yet???
(in reply to *JCB*)
       Post #: 34
RE: Great Planes Cherokee ARF - 5/25/2008 7:39:18 PM
sevans16
Status: offline
I got mine in the air today. I flew it with the brand new OS 56FS-a .
I ran the engine up for about 10 mins, the set it a little rich and off to the air. It is a wonderful engine. It has a low smooth idle with only 2 tanks through it. It seems to fly forever on the tank provided. I rarely went over half throttle(still running very rich) and I flew it for about 10 mins with over a half tank left.
The plane flew great. The flaps are really cool but not needed. I need to program in some mixing between the ailerons and elevator. The plane goes in a serious climb when you give it aileron. Other than that it was very smooth and predictable. Quick build!!!.
< Message edited by sevans16 -- 5/25/2008 8:12:35 PM >
AMA# 737516
(in reply to *JCB*)
       Post #: 35
RE: Great Planes Cherokee ARF - 5/25/2008 7:41:50 PM
sevans16
Status: offline
Oh yeah, balance was right on. I installed a 4 cell 2000 NiMh rx battery pack and the FASST rx in the tray provided.
AMA# 737516
       Post #: 36
RE: Great Planes Cherokee ARF - 5/26/2008 2:08:21 AM
H5606
Status: offline
For anybody that has flown both the GP Cherokee and the Pacific Aeromodel Knockabout - do they have similar flying qualities?
< Message edited by H5606 -- 5/26/2008 2:35:11 AM >
       Post #: 37
RE: Great Planes Cherokee ARF - 5/28/2008 12:29:35 AM
*JCB*
Status: offline
sounds good sevans16!! Do you think it will handle 2lbs worth of floats??
       Post #: 38
RE: Great Planes Cherokee ARF - 5/30/2008 1:43:53 AM
sevans16
Status: offline
Humm 2lbs?? Yeah for scale like flight it should be fine and the flaps will help quite a bit with landings. I might lean towards a little more power?? Maybe a 55AX?
AMA# 737516
(in reply to *JCB*)
       Post #: 39
RE: Great Planes Cherokee ARF - 6/2/2008 12:37:58 AM
sevans16
Status: offline
OK, got some more time on her this weekend. Had about 1hr in the air. The thing barely crawls with full flaps and is very stable.
I have about a 1/2 gallon through my OS 56 FS Alpha now and the idle is around 2800 and full throttle tach reading of 10,100 RPM with 15% CP and 13x6 APC sport prop.
AMA# 737516
       Post #: 40
RE: Great Planes Cherokee ARF - 6/3/2008 11:37:51 PM
