sqeakalong
MI, USA Status: offline
Flew my Cherokee last night on its maiden flight: new plane, new engine, new radio (Oh boy...). Real nice flying airplane. Needed a bit of down elev. and a couple of clicks of left aileron to fly hands off from the beginning of the flight. The O.S. .46AX was running rich but this plane would scoot at 1/2 throttle or so..can only imagine how fast when the engine get broken in. BTY: that Bison muffler sounds real nice with this engine. The O.S. engine started, brand new, on the second hand flip (!!) and never looked back. What a nice engine. Did loops, rolls, etc. and the Cherokee flew great. Handed it off to a couple of fellow flyers and they were impressed with the smoothness of the flight. The straight ahead stall was unbelievable: very soft and kind of hung in there still flying 'til I finally just flew it away; never dropped a wing! Had too much flap though: when I used the flaps (which are very effective!) the Cherokee shot straight up about 15 feet or so. Was having so much fun flying the Cherokee that when I finally HAD to land I came in over the trees (new field; first landing) and the plane was moving a bit faster than I would have liked, was about 15 feet over the grass and applied the flaps. HOLY#*^$@%!! Up the plane rose and...and...the engine decided that was a great time to quit. The end of the runway was coming on and a valley and trees were looming. Put the plane down on the runway and ended up with the front wheelpant poking a hole through the balsa under the fuel tank, and one landing gear block broke loose. Didn't break my wooden prop though . We re-programmed about half the previous flap deflection and it should be much more docile. Plan to have the minor repairs finished in time to go fly it again tonight! This plane flys great and was worth the trouble to make the corrections during the build. I will, however, remove the wheelpants (not great on a rough grass field, even during the takeoff roll) and replace the soft sponge rubber tires with some applicable sized DU-BRO tires. Other than that we are good to go.
