Align gear grease vs. something else?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> Align gear grease vs. something else?
Page: [1]
Login
Align gear grease vs. something else? - 4/29/2008 5:48:48 PM
high flyer 777
Status: offline
Is the Align gear grease that comes with the build kit suffient?
Or should you step-up to something better? Teflon, etc. If
so, what brand or brands?
       Post #: 1
RE: Align gear grease vs. something else? - 4/29/2008 6:39:10 PM
Skarn
Status: offline
You got gear grease with your kit? Are you sure? If you are referring to either the blue or green bottles, that isn't gear grease. They are locktite...the blue is stronger and used for metal-on-metal whereas the green one is for bearings and such.
Good luck!
Skarn
(in reply to high flyer 777)
       Post #: 2
RE: Align gear grease vs. something else? - 4/29/2008 6:48:11 PM
high flyer 777
Status: offline
Those 2 bottles of locktite came w/the build, also the tube of
grease too.
(in reply to Skarn)
       Post #: 3
RE: Align gear grease vs. something else? - 4/29/2008 6:51:52 PM
Skarn
Status: offline
Wow, I guess I got jipped then!
For what it's worth, I don't grease anything and all is fine. I do use a light oil for the swash, and tail slider every so often.
Skarn
       Post #: 4
RE: Align gear grease vs. something else? - 4/29/2008 7:04:49 PM
Burntt32
Status: offline
i missed out on the grease too! i use tri-flo oil for my shafts/bearings etc.
_____________________________
Align T-rex 450 se v2/ Blade CX2
(in reply to Skarn)
       Post #: 5
RE: Align gear grease vs. something else? - 4/29/2008 8:32:21 PM
rftusa2008
Status: offline
mine too, no grease and i got mine last month. i use regular gun grease on mine.
(in reply to Burntt32)
       Post #: 6
RE: Align gear grease vs. something else? - 4/29/2008 8:38:17 PM
BarracudaHockey
Status: offline
Its for the one way bearing, it comes in the kits with the newer swashplate so if you bought one now that wasn't sitting around a while you'd get a few improvements.
I use triflow in the one way so if you're really feeling sorry that you didn't get any I could send you a tube.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to rftusa2008)
       Post #: 7
RE: Align gear grease vs. something else? - 4/29/2008 8:47:12 PM
rftusa2008
Status: offline
They have different version of SE V2's? I didn't grease my one way bearing. Have to do that when I get home.
(in reply to BarracudaHockey)
       Post #: 8
RE: Align gear grease vs. something else? - 4/29/2008 10:46:17 PM
Burntt32
Status: offline
oh man, barracude, what were the differences between the newer/older v2's?
       Post #: 9
RE: Align gear grease vs. something else? - 4/30/2008 3:38:28 AM
goldslinger
Status: offline
It's probably for the main grip thrust bearings.
You can grease the one way bearing and it will Love You for it and last forever.
I also grease the mainshaft and the tail bearings. Oil slings out almost instantly on those especially on the tail.
All other bearings You can Tri-flow oil if You wish.
Gary
" No Excuse for My Failures; No apologies for My Success."
_____________________________________________
       Post #: 10
RE: Align gear grease vs. something else? - 4/30/2008 4:54:43 PM
BarracudaHockey
Status: offline
I may be wrong but the latest runs of the kits include one way grease, a stiffer plastic fan, and a new swash, that has writing on the top.
(in reply to goldslinger)
       Post #: 11
RE: Align gear grease vs. something else? - 4/30/2008 7:43:11 PM
Skarn
Status: offline
What is a plastic fan?
Interesting, I didn't realize they updated the v2...shouldn't it then be a v3? Heh
Skarn
       Post #: 12
RE: Align gear grease vs. something else? - 4/30/2008 11:12:48 PM
Burntt32
Status: offline
v2.1 ha
(in reply to Skarn)
       Post #: 13
RE: Align gear grease vs. something else? - 5/8/2008 4:15:07 AM
goldslinger
Status: offline
quote:
ORIGINAL: BarracudaHockey
No,
I'm sure You're right; didn't read Your post before posting mine; sorry.
Gary
       Post #: 14
RE: Align gear grease vs. something else? - 5/8/2008 4:16:14 AM
goldslinger
Status: offline
On the autorotional gear; they stiffened it I guess Barracuda's saying.
(in reply to Skarn)
       Post #: 15
Page:   [1]
Page: [1]
