Death of a WillHobby FW 190
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Ju-878 Stuka - ARF
Seller:  BAGOSTIX
Details:   $2,400.00   |  6/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Death of a WillHobby FW 190
Page: [1] 2   next >   >>
Login
Death of a WillHobby FW 190 - 4/29/2008 8:28:19 PM
KentuckyColonel
Status: offline
Nothing else to say.. other than the cause is obvious. I forgot to put Fritz in the cockpit before the flight! How can a plane fly without a pilot? Watch the video and you'll see! They don't!
       Post #: 1
RE: Death of a WillHobby FW 190 - 4/29/2008 8:57:11 PM
jmohn
Status: offline
That's sad to see! Sorry about your loss Did you determine what happened?
Jeff
_____________________________
Courage is what it takes to stand up and speak; courage is also what it takes to sit down and listen.
(in reply to KentuckyColonel)
       Post #: 2
RE: Death of a WillHobby FW 190 - 4/29/2008 9:05:23 PM
KentuckyColonel
Status: offline
Left aileron came loose. Seems that the CA didn't seep in as well as it should have. This was my first build bigger than a .46 and no one bothered to tell me little secrets, like using pins to help secure the hinges. Next time, trust me, they'll be pinned!
(in reply to jmohn)
       Post #: 3
RE: Death of a WillHobby FW 190 - 4/29/2008 9:24:11 PM
jmohn
Status: offline
I had one just like that with a P40. Total loss on that plane too. It was a great looking plane!
       Post #: 4
RE: Death of a WillHobby FW 190 - 4/29/2008 9:36:24 PM
Evil_Merlin
Status: offline
Ouch.
Sorry for your lost KC! I know how much of a pain it was for you just to get the darn thing!
(in reply to jmohn)
       Post #: 5
RE: Death of a WillHobby FW 190 - 4/29/2008 9:50:27 PM
mboland
Status: offline
Sorry to see such a nice war bird go in. And it started flying so nicely
It does look fixable.
Don't you just love all the great advice you get when you take the carcass back to the pits.
My first big ARF, a Spitfire with a 90ST in it, lost the elevator on the 5th flight. First comments "didn't you pin the hinges? you should always pin the hinges"
Thanks for telling me AFTER the event
It's the quality of life that counts, not the quantity.
(in reply to jmohn)
       Post #: 6
RE: Death of a WillHobby FW 190 - 4/29/2008 9:55:39 PM
KentuckyColonel
Status: offline
quote:
ORIGINAL: mboland
I think we have the same people in the pits!
(in reply to mboland)
       Post #: 7
RE: Death of a WillHobby FW 190 - 4/29/2008 11:27:48 PM
Corsair 29
Status: online
That right horizontal stab doesn't look right. It seems like it's bent or bending downward as soon as you took off. Can you verify this? I paused it during the climb.
       Post #: 8
RE: Death of a WillHobby FW 190 - 4/30/2008 12:29:50 AM
KentuckyColonel
Status: offline
Both right and left had a very slight equal downward angle. I looked at the video and think I see what you saw, and it was nowhere near how it looked in the video. Both were still in place after the crash.
(in reply to Corsair 29)
       Post #: 9
RE: Death of a WillHobby FW 190 - 4/30/2008 1:18:01 AM
Adonis
Status: offline
I would bet money on reversed ailerons. It goes through the typical gyrations of reversed aileron flight. Gradual turn to the left and then the bank increases as the modeler tries to compensate, eventually it’s in a full spin. When it get inverted in a few spins in frustration and confusion the modeler gives full opposite aileron and it spins the other way, I’ve seen it many times. I watched the video very closely and the ailerons are firmly attached, at least until impact when most likely the servo came loose and tor the aileron off.
Here are some videos of what I mean:
Reversed aileron videohttp://www.youtube.com/watch?v=1cwmT5hmI3U
Another reversed aileron video!http://www.youtube.com/watch?v=ikJV7b54T4I
It happens to us all
       Post #: 10
RE: Death of a WillHobby FW 190 - 4/30/2008 1:23:25 AM
mobyal
Status: offline
Man
Sorry to see that happen. I feel your pain!
What engine's in there and how did it fare? OK? I sure hope so.
Al
MobyAl
       Post #: 11
RE: Death of a WillHobby FW 190 - 4/30/2008 1:51:04 AM
KentuckyColonel
Status: offline
Luck was on my side as far as hardware goes. I tested all the components and everything turned out fine. I don't think it was reversed ailerons. I checked it several times over the past several weeks, as well as having others check it. And unless my Spektrum DX7 reversed them from the time I checked them in preflight and the time it lifted off. I would almost rather have that been the cause, at least then it wouldn't have been from some stupid building mistake. Not saying it wasn't the cause. Funny thing, I'm not all the upset about it. Maybe she was meant to crash from the time the jerk I bought it from on e-bay. Good experience in the build though.
Just checked my radio......just in case. Ailerons are not reversed in it.
(in reply to mobyal)
       Post #: 12
RE: Death of a WillHobby FW 190 - 4/30/2008 1:54:32 AM
KentuckyColonel
Status: offline
quote:
ORIGINAL: Adonis
Just watched the videos. That Mustang was nice...
(in reply to Adonis)
       Post #: 13
RE: Death of a WillHobby FW 190 - 4/30/2008 6:49:25 AM
Black Drape
Status: offline
KC
Dang that's a dirty shame. I agree with you I don't think your ailerons were reversed. It looks like it started to spin to the left and then it ended up spinning to the right. Do you think it might have stalled? My Zero took off just like your 190, climbing straight up, I'm very lucky it didn't stall. I ended up with full down trim to get it to fly level. I noticed in your video that the elevater hinges had come loose, if they had come loose in the air, that could have caused a stall. I did not use the hinges that came with my kit, I used Dubro pinned hinges. I'm not real crazy about ca hinges especially on a nice model like yours. Sure too bad, very sorry to see that happen.
Ron
       Post #: 14
RE: Death of a WillHobby FW 190 - 4/30/2008 7:21:34 AM
vertical grimmace
Status: online
It does look like a stall and then a secondary stall the other way. Especially if you had a lower power setting. That angle of attack was very steep for a model like that especially for not being at full power.
(in reply to Black Drape)
       Post #: 15
RE: Death of a WillHobby FW 190 - 4/30/2008 2:11:08 PM
G-Pete
Status: offline
quote:
ORIGINAL: Adonis
Yesterday when I watched that video I thought exactly the same. But I did not post my thought.
Today I watched the video a few times in slow motion and could not find anything wrong or loose on the airframe.
What I noticed was right in this moment when the airplane started to bank to the left, someone shouted out loud. It appears to me it was the pilot. It supposed to make a right bank.
As you stated, it happen to the best. We all do our little stupid things, it never happened to me (reversed aileron) but I lost airplanes like, not flying with extended antenna – hehehe
Here is a video of a Seagull Yak 54, watch closely how the aileron comes loose on that airplane. It got dragged for awhile and then departed. The Yak looses a lot lift because almost 1/3 of the wing is gone you will see what happen…
click here for the video
Anyhow, sorry for your loss Kentucky. It looks like you just plugged wrong…
