RE: stalls
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> RE: stalls
Page: <<   < prev  1 [2]
Login
RE: stalls - 5/6/2008 6:21:48 PM
str8jailbird
Status: offline
OK bogging down a little. Is this your first nitro? These engines run with rpms varying from 3000 to 40000 rpms. when your engine is finally broken in slightly lean it out because break in settings are rich. If it is almost redlning then richen it 1/16 to be safe. It sounds to me like your One Way Bearig is slipping on your 2-speed assembly. take apart your 2-speed and remove the OWB (use your manual for a schematic). Soak your OWB in denatured alcohol. If you don't have any then brake cleaner or a autaomotive degreaser solvent will work such as carb cleaner. I used Birchwood Casey'e gun scrubber (used on firearms and available at Wal-Mart) on mine. Keep in mind to not get these solvent on plastics. Let the OWB dry and oil it using WD-40 or OWB oil. reassemble and try it out.
(in reply to sillared)
       Post #: 26
RE: stalls - 5/6/2008 11:09:32 PM
BioRev
Status: offline
Silla even when a engine is very rich once it heats to operating temp it leans out a bit and as long as the engine is running it should atleast go faster then a walking pace, It's probly the OWB and needs to be cleaned, Due to lack of Detail we cant really tell you exactly wuts going on until you give us FULL DETAIL! tells us if your engine is revving and not going anywhere or does it just stall. Info plz
       Post #: 27
RE: stalls - 5/6/2008 11:16:39 PM
BAJABANDIT
Status: offline
Dude I couldnt keep mine runnin for breakin with the stock settings I had to lean it about an 1/8th just to break..... Try leaning it one half turn then start it and work from there! Riching it that is!
       Post #: 28
RE: stalls - 5/6/2008 11:19:18 PM
BAJABANDIT
Status: offline
Mine didnt move worth a crap till I tightened my slipper too!
also had to mess with my 2 speed shifty thingymajiger!LOL
(in reply to BAJABANDIT)
       Post #: 29
RE: stalls - 5/7/2008 2:05:07 AM
BioRev
Status: offline
Yea, i had to lean the crap out of my new engine just to break it in and its still slobbering rich. The recomended needle settings that came in the engine manual where to lean the engine didnt even start lol
       Post #: 30
RE: stalls - 5/7/2008 4:59:28 AM
BAJABANDIT
Status: offline
Ya you pretty much cant listen to the manual!!!!!
You have to do it from knowledge!!!!!
Damn just seen I busted my engine mount!
(in reply to BioRev)
       Post #: 31
RE: stalls - 5/7/2008 5:46:56 PM
SAVAGEJIM
Status: offline
quote:
ORIGINAL: BAJABANDIT
I totally agree here, and not just for a Mach engine or any other Losi engine, but for ALL of or car/truck nitro engines. These manuals have the needle setting so rich that trying to start them at factory setting is nearly impossible.
For me, whenever I start any engine, especially for breaking it in, I always preheat the engine to 200degrees F (or as close to it as possible). I do use the factory setting as a starting point, but I have turned the needles in by as much as a whole turn to get the engine right for break-in.
_____________________________
I hate stray Tomcats
       Post #: 32
RE: stalls - 5/7/2008 7:14:06 PM
BAJABANDIT
Status: offline
I think they do it in a perfect enviroment with cheap fuel!! LOL
Like in a tararium or something! (spelling
(in reply to SAVAGEJIM)
       Post #: 33
RE: stalls - 5/7/2008 7:56:42 PM
Sugafree
Status: online
It's funny that the Losi Manual and the Engine Manuals are All Different thought......
This is from the Aftershock Manual,
Base Start-up Settings from the factory
High-Speed Needle 3 turns out from bottom
Low-Speed Needle 3 turns out from bottom
And this is From the M26SS Manual,
We suggest the following settings for breaking in your engine:
High-Speed Needle: 3 turns out (counterclockwise)from closed.
Low-Speed Needle: 2 1/4 turns out (counterclockwise)from closed.
This is from the LST2 Manual,
High-Speed Needle 4 turns out from bottom
Low-Speed Needle 2 turns out from bottom
and From the 427 Manual,
High-Speed Needle: 2 1/2 turns out (counterclockwise)
from closed.
Low-Speed Needle: 2 1/2 turns out (counterclockwise)
from closed.
This is from the LST1 Manual,
High-Speed Needle 2 1/2 turns out from bottom
And the Mach 26 Manual,
High-Speed Needle: 3 1/2 turns out (counterclockwise)
from closed.
Low-Speed Needle: 2 turns out (counterclockwise)
from closed.
       Post #: 34
RE: stalls - 5/7/2008 9:18:42 PM
BAJABANDIT
Status: offline
My point exactly !!! 1/2 of those are the same engine!
(in reply to Sugafree)
       Post #: 35
RE: stalls - 5/8/2008 4:36:38 PM
BioRev
Status: offline
Yea, if you know what your doing ditch the manual and go with what you know best.
       Post #: 36
Jump to:
Google
