Radio set up for my Q-500 Return -Help!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> General Racing Discussion >> Radio set up for my Q-500 Return -Help! Page: [1]
Login
Radio set up for my Q-500 Return -Help! - 4/30/2008 4:11:12 AM
sehlers
Status: offline
Hello all,
After a 10 year or so hiatus ,I'm back to Race ! Trying to get my old Revlution setup and trimmed ,using my last radio ,which is a
Futaba 8 channel .I used to use a Futaba Super 7 with great results and that was my racing radio before .I'm trying now to use the 8 channel transmitter I used for Sport and fun Fly .
Problem : I can't figure out ,so far , how to reduce Only the down elevator movement .When I learned to do that before ,it was a great thing to have setup ,
however I have slept since then ,and or this radio works different in the setup .I've tried several ways but can't get it . Any Racers that are Futaba radio set up knowledgeable ,
please give me the answer .
Thanks for any help .
Steve Ehlers
72 H
AMA 65430
       Post #: 1
RE: Radio set up for my Q-500 Return -Help! - 4/30/2008 2:11:19 PM
vicman
Status: offline
Steve,
I don't have that radio so I can't tell you exactly how to do it. However I gotta ask, do you have the manual for it? If not you can go to the Futaba website and download one for free.
http://www.futabarc.com/manuals/index.html
Scan down about halfway you should find your radio.
Hope this helps.
Vic
_____________________________
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
(in reply to sehlers)
       Post #: 2
RE: Radio set up for my Q-500 Return -Help! - 4/30/2008 2:21:19 PM
daven
Status: online
I answered on the NMPRA forum also, but I assume you are talking about the 8uaf style transmitter??
If so, you can change in either ATV or DR.
The trick is you have to push the elevator stick forward to adjust the down throw, and pull it back to adjust your up.
Aileron works the same way, but you have to go left or right.
I prefer to use DR, but you need to adjust both high and low rates.
Dave Norman
klasskote.com
supertrc.com
(in reply to vicman)
       Post #: 3
RE: Radio set up for my Q-500 Return -Help! - 4/30/2008 2:26:06 PM
sehlers
Status: offline
Vic ,
Yes ,I have the manual ,but it gives No help I see to do this type of function .I'm going to try Dave's suggestion to see if I'm missing something .
Now that I'm thinking about it ,it should work .
steve
       Post #: 4
RE: Radio set up for my Q-500 Return -Help! - 5/1/2008 1:18:24 AM
Bozarth
Status: offline
Dave's suggestion does not work on a standard 8UA transmitter - maybe on a "Super", but not on a standard 8UA. The standard 8UA only has one value for high rate, and only one value for low rate. You cannot differentiate between up and down on elevators or left and right on ailerons while in the DR menu. You can on the 9CAP and greater. I have wrestled with this one myself, and replaced my old beater 8UAP for this exact reason.
I have read too many responses from people who are just guessing.
Not guessing,
Kurt Bozarth
       Post #: 5
RE: Radio set up for my Q-500 Return -Help! - 5/1/2008 1:43:38 AM
sehlers
Status: offline
Kurt ,
Your right as I had already tried that .I thought I would try again to see if I was Brain F_rted this morning and no joy as I thought .
steve
(in reply to Bozarth)
       Post #: 6
RE: Radio set up for my Q-500 Return -Help! - 5/1/2008 12:16:37 PM
daven
Status: online
Yep, mine is the S (Super Version). Didn't know the non S couldn't do that.
Sorry for the bad info.
Dave Norman
klasskote.com
supertrc.com
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
