RE: World Models 33% Ultimate
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: World Models 33% Ultimate
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: World Models 33% Ultimate - 5/11/2008 9:08:15 PM
Francis L M
Status: offline
oooops 9.9Kg = 21.82lb
_____________________________
score55
(in reply to Thunderbolt47)
       Post #: 26
RE: World Models 33% Ultimate - 5/14/2008 12:11:37 PM
Francis L M
Status: offline
I have decided to modify the two bottom wings,
I did not like the way the manufacturer decided to hold them together.
They state in the manual to place a small self tap screw, through the wing into the wing tube.
You can see it in P10 in the manual.
http://www.theworldmodels.com/para/instruction/instructionManuals.php
Don’t like the idea.
score55
(in reply to Francis L M)
       Post #: 27
RE: World Models 33% Ultimate - 5/14/2008 12:14:08 PM
Francis L M
Status: offline
I placed the tube into the wing then I put the wing in its place in the fuselage,
I marked a hole from the inside of the fuselage and I drilled a pilot hole,
this gave me a starting point to drill the rib on the wing.
By cutting into the wing at the edge just before the end rib,
I did a small hole just to get the blind nut through,
by having the pilot hole predrilled I can now drilled a 5mil hole,
and then it was just a case of gluing the blind nut through the 5mil hole.
Click to see fullsize image.
Click for fullsize
Click for fullsize
score55
       Post #: 28
RE: World Models 33% Ultimate - 5/14/2008 12:23:25 PM
Francis L M
Status: offline
Here you have more pictures
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
score55
       Post #: 29
RE: World Models 33% Ultimate - 5/14/2008 12:25:22 PM
Francis L M
Status: offline
I then placed the wing back to the fuselage and tested the fitting, A.OK.
After the testing I placed at the underside of the fuselage balsa strips,
So when I start with the covering of the model I can leave this slots uncovered to access the M5 screws.
score55
       Post #: 30
RE: World Models 33% Ultimate - 5/14/2008 12:50:58 PM
Francis L M
Status: offline
Well going back to the firewall.
First off all I drilled holes off M2 all around the firewall to pin it up,
By getting the cloth of Fiberglas I made a template of the front of the firewall.
And all around to do the re-enforcement
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Francis L M -- 5/14/2008 12:59:09 PM >
score55
       Post #: 31
RE: World Models 33% Ultimate - 5/14/2008 1:01:21 PM
Francis L M
Status: offline
Then I went and epoxy all the inside off the engine box, the outside with 30 Min
Z-Epoxy.
I added to the outside of the engine box a good amount off the 30min all around the surfaces.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
score55
       Post #: 32
RE: World Models 33% Ultimate - 5/14/2008 1:14:13 PM
Francis L M
Status: offline
After all the epoxy has been dried, I covered the model and sprayed all with fuel proof
Paint to finish off the work.
Then it’s just a mutter to start putting all the firewall components back together.
Engine exhaust and CDI
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
score55
       Post #: 33
RE: World Models 33% Ultimate - 5/15/2008 1:29:48 PM
Francis L M
Status: offline
Again I have decided to change the way to fix the top wing better and much easyer to put together.
I made two pieces out of light ply to the same shape of the aerofoil of the top wing.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Francis L M -- 5/15/2008 1:39:30 PM >
score55
       Post #: 34
RE: World Models 33% Ultimate - 5/15/2008 1:38:29 PM
Francis L M
Status: offline
After marking out the templates i then went and dry fitted the ply to the two wings.
Then I drilled the two ply with a M5 drill bit, this will be more than sufficient to hold the two
Wing together.
Click for fullsize
Click for fullsize
Click for fullsize
score55
       Post #: 35
RE: World Models 33% Ultimate - 5/15/2008 1:55:23 PM
Francis L M
Status: offline
I placed the two pieces of ply together to and added a spacer of 5mil to compensate for the aluminium bracket,
by mixing some 5 Mini epoxy I added the glue to the two wings and the ply,
then I carefully placed the two pieces of ply to each end of the wings with the aluminium tube and bracket.
After the epoxy was completely dry I then drilled three holes of M2,
then I added pins to strengthen the ply to the wing rib don’t think It needs it just in case.
I am more than satisfied with this job.
Click for fullsize
Click for fullsize
< Message edited by Francis L M -- 5/15/2008 1:56:44 PM >
score55
       Post #: 36
RE: World Models 33% Ultimate - 5/15/2008 2:03:09 PM
Francis L M
Status: offline
I have more or less done the same job to the tail plain.
like i sed before just did not like the way they are fixing the tail plane with just a selftap screw.
maybe its ok but not for me.
Click for fullsize
Click for fullsize
Click for fullsize
score55
       Post #: 37
RE: World Models 33% Ultimate - 5/15/2008 2:05:36 PM
Francis L M
Status: offline
More pictures
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Francis L M -- 5/15/2008 2:14:20 PM >
score55
       Post #: 38
RE: World Models 33% Ultimate - 5/15/2008 2:13:04 PM
Francis L M
Status: offline
two more
Click for fullsize
Click for fullsize
Click for fullsize
score55
