AHR43
TX, USA Status: offline
quote:
ORIGINAL: BigShrimpah Would locking the diff help any? The problem I have is when nailing it from a dead stop it will just spin and balloon the tires and usually hook one way or the other. It is already at the lowest shock settings it will go, and the drag racers out there tell me to run the back as soft as I can not stiff. Locking the diff definitely helped the performance of the R1E when I was running it. For a while I even did away with the slipper clutch and went back to old-style TRX spur gear adapter. Not a good choice. Slipper clutch is a useful aid in controlling the launch once I locked the diff using J-B Weld. I took the planet shafts and the planet gears out of the diff too. Just J-B'd the sun gears and sun gear alignment shafts together. Gotta be sure that's what you want to do thought. You can't undo it it once it's done. Even took out the (4) screws that held the side cover plate on. J-B epoxied EVERYTHING together. No need for for spinning that rotating weight either. But, alas, the main diif gear proved the weak link for RC drag racing a conversion old-school Rustler. Had to back off to using a 19t Spec Motor to keep from eating up a diff gear at an inopportune race time. After that, it was run after run after run...no problemo. Not sure how all this applies to "new generation" TRX cars. Refer to your owners manual, and use your best judgement. Good luck.
_____________________________
Arnie Hauswald Racing 1943 RC Electric Drag Racing
