servo's wont respond!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Radio Equipment >> servo's wont respond!!
Page: [1]
Login
servo's wont respond!! - 5/1/2008 2:36:15 AM
MATT55
Status: offline
i have a spektrum dx 2.0 and i did the quick setup in the instructions and the servos arent responding..
please help!
       Post #: 1
RE: servo's wont respond!! - 5/1/2008 3:14:57 AM
systemlord
Status: offline
quote:
ORIGINAL: MATT55
please help!
Do you have modulation modes from which to choose from? My Futaba radio has three modulation modes (PCM, HRS PPM) one of which is PCM, the servos don't respond because the receiver doesn't support PCM. Hope this helps.
_____________________________
UE SuperMaxx 1/8th Monster Truck* Custom Duratrax Vendetta Mamba 25 Motor 5400kv Impulse 3S1P 11.1v 950mAH 25C * Raptor 60
(in reply to MATT55)
       Post #: 2
RE: servo's wont respond!! - 5/1/2008 3:27:53 AM
MATT55
Status: offline
well now whenever i turn the wheel on the radio it starts to steer then the LED on the receiver turns off, and the throttle barle nudges and does the same
(in reply to systemlord)
       Post #: 3
RE: servo's wont respond!! - 5/1/2008 3:54:36 AM
systemlord
Status: offline
quote:
ORIGINAL: MATT55
It seems like your radio is loosing signal shortly after you move a servo or your batteries are low causing the receiver to activate the fail safe feature. My receiver has a little botton on it for resetting or re-aquiring the signal. Check your battery voltage.
       Post #: 4
RE: servo's wont respond!! - 5/1/2008 12:05:03 PM
nomobux
Status: offline
quote:
ORIGINAL: MATT55
Low batt
" I GOTTS NOMOBUX "
       Post #: 5
RE: servo's wont respond!! - 5/2/2008 1:15:31 AM
MATT55
Status: offline
thats what was wrong, now another question
my throttle isnt working now, it moves only when i hit the brake and it still barley moves then
(in reply to nomobux)
       Post #: 6
RE: servo's wont respond!! - 5/2/2008 2:08:49 AM
nomobux
Status: offline
reverse the throttle/ brake servo setting on the transmitter
" I GOTTS NOMOBUX "
       Post #: 7
RE: servo's wont respond!! - 5/2/2008 2:31:50 AM
systemlord
Status: offline
quote:
ORIGINAL: MATT55
You need to find the neutral or middle point in the servo, to do this you need to have both Tx & Rx turned on. It barely moves because its already at it full turn to the left or right, some servos can't turn 360% degrees. My servos only can do 90% grees turnning left to right.
       Post #: 8
RE: servo's wont respond!! - 5/2/2008 12:31:20 PM
savtraxx
Status: offline
servo not busted?
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.625RCU1
