*Hangar 9 Sure Cycle*
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  4/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> *Hangar 9 Sure Cycle*
Page: [1]
Login
*Hangar 9 Sure Cycle* - 5/1/2008 2:45:32 AM
Zippi
Status: offline
I'm looking for a good battey cycler and charger. How fast will this charge an 1800 NI-MH pack? What are the pro's & con's on this cycler? Anything out there any better for about the same price or less than $100.00?
_____________________________
"It Ain't Lookin Good"
http://zippi.50webs.com/index.htm
       Post #: 1
RE: *Hangar 9 Sure Cycle* - 5/1/2008 4:57:23 PM
pilotpete2
Status: offline
Hi Zippi,
This cycler has two charge rates 50 and 150mA, so at the 150mA rate you would charge an 1800mAh pack for at least 16 hours, this is not a peak detecting fast charger, strictly for overnite C/10 charging. Ditto for the $62.00 Hobbico Accucycle. I use the old Ace Digipace II, basically the same setup[)] work fine and last a long time
Good luck,
Pete
(in reply to Zippi)
       Post #: 2
RE: *Hangar 9 Sure Cycle* - 5/2/2008 12:35:20 PM
Zippi
Status: offline
Something that would charge a little faster would be nice. Any other suggestions?
(in reply to pilotpete2)
       Post #: 3
RE: *Hangar 9 Sure Cycle* - 5/2/2008 3:22:04 PM
pilotpete2
Status: offline
The Accucycle Elite will do it all, but it does go for 130 bucks.
You also could consider a combo of the cycler/overnite charger and an inexpensive fast field charger such as the Hobbico quick field charger.
BTW, the H9 cycler is strictly A/C input, the Accucycle Elite I mentioned is a 12Vdc input, so you would need a power supply to run it.
Good luck,
Pete
(in reply to Zippi)
       Post #: 4
RE: *Hangar 9 Sure Cycle* - 5/2/2008 10:10:39 PM
Zippi
Status: offline
pilotpete2,
Thanks for the info. We have 120 at all our tables at the field so I was looking for that.
       Post #: 5
RE: *Hangar 9 Sure Cycle* - 5/3/2008 1:18:24 AM
pilotpete2
Status: offline
Hi Zippi,
120Vac available at your tables, neat I like that, it would reduce the need for the jumper cables we use at our field when the inevitable happens and someones car won't start
Pete
(in reply to Zippi)
       Post #: 6
RE: *Hangar 9 Sure Cycle* - 5/3/2008 7:23:40 PM
KB9STD
Status: offline
Zippy,The Sure Cycle is great as a battery cycler.(Ask Mike Williams,He has one and will probably let You try it out).
It's a simple unit,and it's easy("simple" ) to use!It offers 2 charge rates to accomodate large receiver packs,and reversible polarity for JR/Spektrum transmitters.Everything You need in a "Cycler/Tester".
Fast charge rates shouldn't be a concern in a cycler.Battery cycling(Whether for testing,or "Equalizing" a pack)is a slow process.The Slow "Overnight" charge is part of the process,and fast charging just won't get the job done.
Having 1 unit for all your battery needs sounds appealing.But putting everything in 1 box means either compromising on performance,or on price.Fast charging doesn't make a better cycler,and a cycler is no use "at the field".
So,I highly reccomend the Sure Cycle! And I reccomend a seperate "Fast Charger" for "at the Field" use.Whether the Field charger is 120 volt,or you use a seperate "Power Supply" is irrelevant.(I think there is a converted computer power supply available at the field anyway).Hope this helps, Jeff K.
< Message edited by KB9STD -- 5/3/2008 7:29:07 PM >
       Post #: 7
RE: *Hangar 9 Sure Cycle* - 5/3/2008 9:40:22 PM
pilotpete2
Status: offline
Hey Zipi,
Y'know until you mentioned the 120Vac at your field I was thinking you were dealing with receiver packs, but if you are into E-flight that's a whole nuther issue, there you will need the fast peak detecting charger.
One point I missed when referring to the Accu cycle Elite, this charger while a little over your budget is a very flexible unit and it is ac/dc, it comes with a "brick" type power supply, so you could run this one directly off ac at the field.
Pete
(in reply to Zippi)
       Post #: 8
RE: *Hangar 9 Sure Cycle* - 5/5/2008 12:11:42 PM
Zippi
Status: offline
Thanks for the info guys.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
