Questions on the Gitchel parachute
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> R/C Sky Diving >> Questions on the Gitchel parachute
Page: [1]
Login
Questions on the Gitchel parachute - 5/1/2008 4:06:55 AM
FlyBy8
Status: offline
Ok guys, I am looking for some guidance here on putting together a jumper/parachute from scratch.
I have downloaded the Gitchel plans from John and Bob's RC Skydiving web page. http://www.mindspring.com/~sanyo1/ Thanks John and Bob. Nice web site.
Couple of questions.
1) These plans make a 49 inch wide chute. What was the origional span for the Gitchel plans?
2) Is the modified Gitchel plans at 49 inches a good match for a 18" Juan built jumper? Santa was kind to me this year and delivered one to my supirse.
3) What is a good source for the line material? I have read where people have used planer board line, catfish fishing line, trotline, etc. What seems to work best for the combination I have outlined above?
4) Is there a better way to connect the lines to the chute? The plan calls for sewing the lines directly to the rib/bottom pannels.
At this point I have:
Drafted out the plans for the rib and bottom panel onto paper. Cut the paper pattern out and transfered it to aluminum and cut the rib template out.
Purchased three yards of rip stop nylon material.
Ordered and waiting on the hot knife to arrive from Tower.
Taken my first sewing class from my dear mother. Don't laugh, I think I can do this. We cut a few ribs, a canopy and bottom panels out of some scrap material and practiced a little last weekend.
Any help and guidenance you can provide will be greatly appreciated.
Paul
       Post #: 1
RE: Questions on the Gitchel parachute - 5/2/2008 4:44:09 AM
GaryV
Status: offline
Same, I got my plans from Wally himself
Depends on weight, needs to be 2.5 to 3 Lbs. If to light add weight, lead
Paragear.com - fabric, braided kite line for rigging, Dacron ( I found some that works good for no knot loops, but I can't recall the vendor right now.)
Yes, but I need to go to bed, I'll get back with you on this.
GaryV
(in reply to FlyBy8)
       Post #: 2
RE: Questions on the Gitchel parachute - 5/2/2008 12:24:41 PM
goldenknight1
Status: offline
flyby8:
If you go on line to www.intothewind.com they have a kite line called ashway woven dacron use the use the 50 pound line it is very strong and will not kink or bind when it gets a loop in it. I use to make gitchell and what I did was sew small loops on canopy where lines attached and this worked very well for me. If anyone else had a way of doing it they will let you know. I hope this will help you in getting your chute up and flying.
BOB[)][)]
       Post #: 3
RE: Questions on the Gitchel parachute - 5/2/2008 11:48:33 PM
FlyBy8
Status: offline
Thanks Bob and Gary.
After reading many posts on this forum, I figured you guys would be able to help.
Bob, what material did you use for the loops? Same rip stop Nylon as the chute or something different. Then did you tie the lines directly to the loops?
(in reply to goldenknight1)
       Post #: 4
RE: Questions on the Gitchel parachute - 5/3/2008 12:48:54 AM
goldenknight1
Status: offline
Flyby8
yes I used the left overs from the material that I cut the chute from, I would mark the dividers for the cells so that when I started sewing I would sew the loops in where the marks were . Make your loops a 1/4 of a inch wide and they should be a 1 1/2 long fold the material in half so that you have a loop 3/4 of a inch long to sew on the chute, sew a 1/4 of a inch of the loop in the chute. and yes all I did was put the line thru the loop and tie a square knot in the line.
BOB
       Post #: 5
RE: Questions on the Gitchel parachute - 5/3/2008 12:56:51 AM
FlyBy8
Status: offline
Great info Bob,
That should make it a lot easier than trying to keep all the lines untangled while sewing and also help if I need to re-rig a line.
Found the ashway woven dacron 50 pound line and ordered a 1000 ft. spool. That ought to do it...
Got the hot knife in yesterday, so tonight I should be cutting out some parts.
Do you usually leave enought material to hem the leading edge of both the canopy and bottom pannels?
Thanks for all your help.
Paul
       Post #: 6
RE: Questions on the Gitchel parachute - 5/3/2008 2:29:42 AM
goldenknight1
Status: offline
fLYBY8
I FOUND THAT YOU GET A GOOD CLEAN CUT WITH THE HOT KNIFE THAT I DID NOT HAVE TO HEM THE OPENING ON THE GITCHELL AND FOUND THAT YOU WOULD HAVE A GOOD CLEAN OPENING WHEN DEPLOYING THE CHUTE. NEXT DO NOT MAKE A 8 INCH PILOT CHUTE MAKE IT 10 INCHES AND WHEN YOU PUT PILOT CHUTE ON CANOPY MEASURE BACK FROM THE LEADING EDGE OF THE TO OF CHUTE AND ATTACH THE PILOT CHUTE 10 INCHES BACK ON THE VERY CENTER OF CHUTE. ALSO PUT 8 LINE ON PILOT CHUTE , THE LINES SHOULD BE 14 INCHES LONG, PULL ALL THE LINE ON THE BOTTOM OF PILOT CHUTE SO THAT THEY ARE ALL THE SAME LENGTH NOW YOU WILL CUT A SINGLE LINE ABOUT 20 INCHES LONG YOU WANT TO TAKE THIS LINE AND AND TIE IT WITH THE LINE ON PILOT CHUTE AT AT ABOUT TEN INCHES DOWN FROM PILOT CHUTE. WHEN ATTACHING PILOT CHUTE TO CANOPY YOU WANT THE PILOT CHUTR COME PAST THE TRAILING EDGE OF MAIN CANOPY AT LEAST 2 INCHES. WHEN YOU HAVE READY TO TIE TIE IT ON MAIN AND CUT OFF EXCESS LINE , IF YO HAVE ANYMORE QUESTION LET ME KNOW .
BOB [)]
       Post #: 7
RE: Questions on the Gitchel parachute - 5/3/2008 3:06:08 PM
FlyBy8
Status: offline
Goldenknight1,
I will keep all of this in mind when I get closer to the end of assemble. I am still in the process of cutting out the parts. Those 1.5 inch circles in the ribs are kind of hard to get cut out.
Anyone got any tips on cutting them?
Paul
       Post #: 8
RE: Questions on the Gitchel parachute - 5/4/2008 5:07:39 AM
FlyBy8
Status: offline
Ok, I learned a few things today.
The hot knife works better when used with a cutting matt and the knife blade must be a sharp fresh one.
Also discovered the the problem I was having related to the rate of speed at which the knife was being pulled.
I slowed down and let the hot knife have more time to do it's job and problem solved.
I am using three colors for this chute and have the two outside sets of cells cut out. Tomorrow, I will tackle the middle section.
       Post #: 9
RE: Questions on the Gitchel parachute - 5/4/2008 4:08:32 PM
Lightfoot
Status: offline
What is the purpose of the holes between the cells? It is simply to equalize the pressure between the cells?
_____________________________
Howard
RCUniverse Forum Manager
R/C Flight Unlimited - http://www.rcfu.com
       Post #: 10
RE: Questions on the Gitchel parachute - 5/4/2008 5:16:22 PM
RLR
Status: offline
Hi
Yes it is there for airflow threw the cells.
I use a 60w soldering iron to cut and its works for me. It is small and light, the tip is not sharp, round becuase the material is being cut with the heat. I cut on normal presboard or chipboard.
Riaan
(in reply to Lightfoot)
       Post #: 11
RE: Questions on the Gitchel parachute - 5/5/2008 3:12:29 AM
GaryV
Status: offline
I have been using 80# braided Dacron kite string from windstarkites.com. It works good for making no tie loops. It was $11.00 for 500ft the last time I ordered it.
I have been trying to post pics, but it hasn't worked out yet.
GaryV
(in reply to RLR)
       Post #: 12
RE: Questions on the Gitchel parachute - 5/5/2008 3:14:03 AM
GaryV
Status: offline
Hi Bob, I see your logged on, Gary
(in reply to GaryV)
       Post #: 13
RE: Questions on the Gitchel parachute - 5/5/2008 3:17:43 AM
GaryV
Status: offline
[image][/image]
Click to see fullsize image.
Click for fullsize
< Message edited by GaryV -- 5/5/2008 3:21:53 AM >
(in reply to GaryV)
       Post #: 14
RE: Questions on the Gitchel parachute - 5/5/2008 3:26:14 AM
GaryV
Status: offline
[image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to GaryV)
       Post #: 15
