huggins
IN, USA Status: offline
quote:
ORIGINAL: Scar quote:
ORIGINAL: huggins I can't actually speak about the DX6 since I do not own one, but with Futaba, INH means that the functionality of the mix is prohibited from working. ACT means that the functionality is activated and available to use during flight. Once activated, the function can be turned on (ACT-ON) and off (ACT-OFF) with a switch (or left on all of the time, not assigned to a switch) anytime during flight. For example if you want flaps, you must activate the flap function in your program, then you can deploy them with a switch during take off and landing but turn them off during regular flight. There are more mixes and available to your program than there are switches on your transmitter. You don't want to be activating stuff that you don't have a need for accidentally by hitting the wrong switch. INH/ACT allows you to customize your program with only the mixes you need and control them how you want. Mike Amazing. A dozen lines to say what Vasek said in his second sentence - without addressing the question. That might be your answer, Vasek! They just like to use more letters than necessary! Good luck, Dave Olson Amazing. I try to answer somebodies question and I am accused of using too many words. While your reference to Vasek's second sentence that he discovered what INH and ACT meant is true, that was NOT the question. The question came in his third sentence when he asked why they don't use on/off terminology instead. This leads me to believe that he did not understand the difference between a mix being inhibited or active vs. being active, but either on or off. Maybe I was wrong, and if so, my appologies to Vasek. My response was my attempt at explaining the difference which most certainly addressed his question. Mike
< Message edited by huggins -- 5/1/2008 5:45:55 PM >
