How much power drain from 12V battery.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> How much power drain from 12V battery.
Page: [1]
Login
How much power drain from 12V battery. - 5/1/2008 4:14:19 PM
gisi
Status: offline
Hi folks.
I have a 12V, 9A field battery with a Hobbico Field charger.
Now, if I'm charging my TX battery which is 9.6V, 2Ah from empty state (Voltage around 9.0V) at 0.6A, how much power would that drain from my field battery?
_____________________________
gisi
       Post #: 1
RE: How much power drain from 12V battery. - 5/1/2008 5:54:39 PM
gadix
Status: offline
600mha - da?
which mean 0.6A per hour
if you pwer supply is a 12v/9000mha and u use only 600mha out of the 9000mha...
so P(watts)= I*V-> 9.6*2000=19200mw-> 19.2w->1.92Kw OK-> this your batt power.
the hobbico have an integrated ciruit that reduces the 12 input the output you need: 4.8 69.6 and so on
bottom line
kirchof electrical law says: any curreny that goes into a "cosumer" is going out the same amount
meaning that if you "demand" via the hobbico 600mha - this is what is going out from the 12v batt, give or take a few mV that are been spread over the hobbico inner circuit itself
GADI,
ISRAEL
(in reply to gisi)
       Post #: 2
RE: How much power drain from 12V battery. - 5/1/2008 6:42:09 PM
gisi
Status: offline
Thanks, good answer!
gisi
(in reply to gadix)
       Post #: 3
RE: How much power drain from 12V battery. - 5/1/2008 6:52:24 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: gisi
Hi folks.
About 20 watt-hours. The battery has about 100 watt-hours available.
Red S.
AMA 951 Leader Member
(in reply to gisi)
       Post #: 4
RE: How much power drain from 12V battery. - 5/1/2008 7:06:22 PM
gisi
Status: offline
quote:
ORIGINAL: Red Scholefield
How do you calculate that?
gisi
(in reply to Red Scholefield)
       Post #: 5
RE: How much power drain from 12V battery. - 5/1/2008 7:13:39 PM
gadix
Status: offline
the main 12v is usualy a 5-7amps
so : p=iv
p=12*7000mA->84000mW->84W->o.84Kw
but you drain only 0.6Amps
so:
12*600->7200mW->7.2W
i wish it was 600W per hour
than you could lite all LA with 10000 batteries - and no more energy crisses
GADI,
ISRAEL
(in reply to gisi)
       Post #: 6
RE: How much power drain from 12V battery. - 5/1/2008 8:10:54 PM
Rodney
Status: offline
What Red said, your battery that you are charging is closer to 10 volts average and you need to put in 2000 mah or 2 amps. times 1 hour (assuming you are charging at 2 amperes). 2 amps times 10 volts = 20 watts. Also, you will have only about an 80% efficiency so really you are using more like 25 watts out of the available 106 in a fully charged field battery.
(in reply to gadix)
       Post #: 7
RE: How much power drain from 12V battery. - 5/2/2008 5:37:56 PM
gisi
Status: offline
Would it be allright for me to charge the field battery whilst charging tx and rx with the field charger?
The charger for my field battery delivers about 1 amps, the field charger charges both tx and rx with 0,3 amps.
gisi
(in reply to Rodney)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU1
