RE: Nitro DR1 tri-plane
Tower Hobbies
Logged in as Guest
  Printable Version
30% SD-Model Yak 54 New In Box ARF - ARF
Seller:  denney47
Details:   $559.95   |  7/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Nitro DR1 tri-plane
Page: <<   < prev  1 [2]
Login
RE: Nitro DR1 tri-plane - 5/28/2008 11:41:20 PM
john cirri
Status: offline
If you put a 26cc in this plane, When you hit the throttle the Plane would stay there, And the Engine and firewall will take off, A good 60 would fly it, I'm using a ST.75 and moved all the servo's up front w/Ni-rods, That will fix any tail weight prob.
(in reply to KenP)
       Post #: 26
RE: Nitro DR1 tri-plane - 5/29/2008 11:44:26 AM
Capt. Crackup
Status: offline
Both the red and the black&yellow look great,,,,,,,Does any one know how they fly??? Thanks Skip D
_____________________________
There's only one thing cooler than Radio Controlled Aircraft,,,,,,,,,,that's the guys that fly em!!
Capt. Crackup
(in reply to john cirri)
       Post #: 27
RE: Nitro DR1 tri-plane - 6/3/2008 2:34:56 AM
john cirri
Status: offline
Im talking with someone on another thread, That say's it fly fine, The balance point is the top wing 58mm from the LE, Mine's almost done, I should have it in the air by the weekend.
(in reply to Capt. Crackup)
       Post #: 28
RE: Nitro DR1 tri-plane - 6/7/2008 5:11:48 AM
Nickens03
Status: offline
My dr 1 rolls to the left on take off can not stop this roll even at full right. have you had this before. Is there a fix. Mike.
(in reply to safeTwire)
       Post #: 29
RE: Nitro DR1 tri-plane - 6/7/2008 5:41:55 AM
john cirri
Status: offline
Haven't flown mine yet, But as long as you don't have left thrust in the engine, Your top wing incidence is flat, It seem's that if it go's that left somethings not straight, Do you have enough aileron throw, Should only take about 20' rollout before it's in the air with a little right rudder.
(in reply to Nickens03)
       Post #: 30
RE: Nitro DR1 tri-plane - 6/7/2008 2:24:38 PM
KenP
Status: offline
I have a smaller DR1 that pulls to the left on almost every take off.
       Post #: 31
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
