Flying using a VPP system - switch or lever
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> VPP - Variable Pitch Prop 4D flying >> Flying using a VPP system - switch or lever
Page: [1]
Login
Flying using a VPP system - switch or lever - 5/2/2008 12:21:26 AM
darticus
Status: offline
Does the plane fly normal in every respect until you use the pitch change. Is the pitch change controlled by a switch or the left throttle lever? On my Realflight it seems as the Vpp is controlled by a toggle switch. You put throttle lever down and flip the top toggle switch for full reverse. Is this the way it should be?
_____________________________
Thanks for your help Guys, FORGEDABOUTIT! Ron
       Post #: 1
RE: Flying using a VPP system - switch or lever - 5/2/2008 9:29:01 AM
Rodine Air Force
Status: offline
No. Throttle stick should control the pitch.
Forward stick position = forward pitch
center position = 0 pitch
Back position = reverse
Without a healthy fear of the ground
(in reply to darticus)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU1
