Concentrate for use with nitro???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Concentrate for use with nitro???
Page: [1]
Login
Concentrate for use with nitro??? - 5/2/2008 7:04:23 PM
balsaeater
Status: online
NB safety info relevant to this thread for home brew mixxes
There are other threads that advise mixing gasoline into nitro methane can make a shock sensitive fuel so verify safety info before mixing
I tried search option but drew a blank
this thread about nitro source
http://www.rcuniverse.com/forum/m_5813036/anchors_5813036/mpage_1/key_/anchor/tm.htm#5813036
leads to also a chemical called super concentrate
http://www.shop.pricechemical.com/category.sc?categoryId=5
for use with gasoline and nitro mixxes
Has anybody any idea what this stuff is chemically and what it does
Also would it be useful in gasser motor to gain more power and would it be usefull to add some to glow fuel with nitromethane mixxes
balsaeater
       Post #: 1
RE: Concentrate for use with nitro??? - 5/2/2008 7:14:23 PM
mpalermo
Status: offline
I have bought from Price chemical before, dont know what that super concentrate is but I asked them for nitro and they send me 99.5% nitro..
it ws like 40 bucks a gallon and 45 bucks shipping for the case.
Call them and ask!!!
(in reply to balsaeater)
       Post #: 2
RE: Concentrate for use with nitro??? - 5/2/2008 7:58:28 PM
balsaeater
Status: online
quote:
ORIGINAL: mpalermo
There is a sorta problem with a 2000 mile pond to ship it over to which bumps price up a lot ???
I think the nitro is 99.5% nitro and 0.5% methanol so as to ensure the fuel wouldn't be shock sensitive which it reputedly can be in 100% pure nitro
I pay E130 euro per UK gallon or ~E100 per USA gal ~ $160 a USA gallon or ~3.5 times more expensive than USA
But even buying the stuff direct paying the HAZMAT rates the import tax will probably make it more expensive maybe 5 times to buy from USA unless the dollar bombs another 50% assuming a USA outfit would export to Europe which most of them wont due to
HAZ MAT problems
As Gasoline here costs ~$7 a USA gallon and if this concentrate would allow me with the cheaper concentrate to drop the nitro level down from say 15% to 3% concentrate 5%nitro I could reduce fuel costs more again
But I may have to ring them to get the specs on this concentrate if the forum draws blank
Balsaeater
(in reply to mpalermo)
       Post #: 3
RE: Concentrate for use with nitro??? - 5/2/2008 9:53:47 PM
brewski
Status: offline
The residual is nitroethane and nitro-propane.
_____________________________
A bad day flying is better than a good day at..........well........maybe not.
Revver Bro #177
       Post #: 4
RE: Concentrate for use with nitro??? - 5/3/2008 3:50:14 AM
downunder
Status: offline
From what I recall, pure nitro can become shock sensitive over time so a dye is put into it which can detect it and changes colour (maybe something like from purple to yellow) but a very small amount of impurity such as methanol eliminates the shock sensitivity.
Another fuel that can become dangerous is model diesel fuel where the ether very slowly leaks out past the cap of the metal cans it's usually stored in. It can crystallise on the threads and when the cap is eventually unscrewed the crystals explode like what we used to call "touch powder" (which I won't say how to make ).
Iso Propyl Nitrate (IPN) is also shock sensitive and when used as a raw fuel all pipe connections had to go from a small to a large connection or the flow could set up a compression which could set it off (it's a mono propellant). I used to have a gallon can of it and I was always very careful not to drop it but I think I was being overly cautious .
(in reply to brewski)
       Post #: 5
RE: Concentrate for use with nitro??? - 5/3/2008 10:04:41 AM
balsaeater
Status: online
quote:
ORIGINAL: downunder
...edit..
Re: downunder
Thanks for the info about that fuel ingredient Iso Propyl Nitrate.
It looks like this might be all or some of the concentrate supplied from the USA Hot cars nitro suppliers
I recall some of the model plane fuel formulas for the tank sized limited fuel competitions control line planes from late 50's to early 60's era included lots of extra components seldom included today such as 5% gasoline 5 % Iso Propyl Nitrate 5% nitromethane and some sorta shoe polish stuff
From the specs of Iso Propyl Nitrate available on line where best I can tell the flame wave front is marginally faster than nitromethane and it has a slow wave flame front more similar to Nitromethane than the rapid flame wave front from methanol or gasoline and a low oxygen requirement to burn like Nitro methane it would make sense to include a few % of this fuel
Best I can figure the methanol would ignite first followed by the Iso Propyl Nitrate followed buy the nitro methane thereby supplying a longer flame wave front and smoother expansion in the down stroke of the piston
(Feel free to correct me if I got it wrong)
This shock sensitivity element for nitromethane best I can figure is very low risk nearly impossible to produce outside a laboratory conditions.
As a mono propellant the nitromethane in rockets last uses were in ~1947 era and the extreme pressures and forces to make nitro methane be a possible mono propellant or a become a shock sensitive fuel are so extreme to be very difficult to succeed to achieve the correct conditions .
The addition of 1% methanol is often done for shipping nitro methane so supplying 99% nitro methane ensures that shock sensitive conditions can never be obtained (with 1% probably being overkill and as little as 0.5% of other contaminants such as Methanol nitroethane and nitro-propane might achieve the same results and 100% pure nitro methane is nearly impossible to archive shock sensitivity)
I suspect the Iso Propyl Nitrate will be similar nearly impossible to achieve shock sensitivity except in the laboratory
I suspect the concentrate will be Iso Propyl Nitrate with some unknown % of methanol fuel combined
But if others know different let me know
I suspect the drag car racing fraternity from the 1960 to 1980 era would know for sure what is the concentrate
I supplied some links for others who might know more chemical stuff than I do
Heavy tecky stuff so most will opt to skip what is below this point or just skim the high points
http://en.wikipedia.org/wiki/Isopropyl_nitrate
quote:
ORIGINAL: en.wikipedia.org
quote from wiki below
Isopropyl nitrate
From Wikipedia, the free encyclopedia
Isopropyl nitrate (IPN, 2-propyl nitrate) is a coloreless liquid monopropellant. It is used as a diesel cetane improver. IPN is a low-sensitivity explosive, with a detonation velocity of approximately 5400 m/s.
Isopropyl nitrate was previously used in a jet engine starting system, primarily by the RAF, and was known as AVPIN. It has also been used as a fuel for power supply and actuation in guided weapons, notably in the British Royal Navy.[1]"
end quote
http://www.intdetsymp.org/detsymp2002/PaperSubmit/FinalManuscript/pdf/Zhang-131.pdf#search=%22%22isopropyl%20nitrate%22%20IPN%22
quote:
ORIGINAL: intdetsymp.org
Quote of the main points from the paper above
"Conclusions
Nitromethane has been used for a long time as a model for the study of detonation physics in homogeneous liquid explosives.
Although modern diagnostic technology is now allowing some of the details of the reaction zone of NM detonation to be resolved, the very small detonation length scale (ca. 6-15 ns17) still presents a challenge in terms of elucidating the mechanism of detonation.
Liquid isopropyl nitrate (IPN) is considered a practical alternative for fundamental studies of detonation due to its larger detonation length scale which facilitates higher diagnostic resolution.
In the present paper, the detonability of IPN has been investigated, including shock initiation of detonation and determination of the critical diameter in low impedance PVC tubes.
Two modes of shock initiation of detonation have been observed: direct initiation of detonation, and SDT with a build-up or onset process
involving detonation in the shock precompressed medium.
While the SDT process is similar to that for NM reported in the literature, the reaction thermal energy in the precompressed medium is
much lower than that observed for NM. The SDT process, from the onset of detonation, through the overdriven mode, and finally to C-J detonation, occurs in a transition distance of about 10-15 mm near the critical shock pressure. Limited data for the initial shock pressure versus the time of onset of detonation and the catch-up time have beenobtained.
The critical shock initiation pressure is estimated to be in the range of 7-8.5 GPa at
0±5 °C.
The critical diameter for neat IPN was found to exceed 310 mm at 16 °C in a low impedance PVC tube. Thus, the critical diameter
for IPN is at least one order of magnitude larger than that for NM."
end quote
EDIT extra info for the avaition version of Isopropyl nitrate AVIPN a small quote
http://www.airliners.net/aviation-forums/tech_ops/read.main/164215/
quote:
ORIGINAL: www.airliners.net
The latter (early) marks, PR7, E15, T17, T22 had 3 per engine, 2 as spares. The last mark, PR9, used a really nasty explosive fuel called AVPIN, which was volatile in the extreme. One of our jeeps carrying the stuff through a small town, fortunately in an unpopulated area, caught fire spontaneously, the driver bailed, and the resultant conflagration melted the concrete of the sidewalk. You can imagine the effect this had on the local populous - we were thereafter banned from transporting it through residential areas.
balsaeater
< Message edited by balsaeater -- 5/3/2008 1:42:14 PM >
(in reply to downunder)
       Post #: 6
RE: Concentrate for use with nitro??? - 5/3/2008 4:57:39 PM
downunder
Status: offline
IPN is one of the favoured additives in model diesel fuel at around the 1% mark as an alternative to amyl nitrate or amyl nitrite. I remember priming a old Mills .75 with straight IPN, one flick and it was running .
It was used as the fuel for the starter motor on the RR Avon Mk 26 as fitted to our Australian Sabre aircraft and seeing I happened to be in the RAAF there was sometimes a bit of IPN laying around.......
       Post #: 7
RE: Concentrate for use with nitro??? - 5/3/2008 8:36:41 PM
balsaeater
Status: online
quote:
ORIGINAL: downunder
....edit....
IPN ........ ......was used as the fuel for the starter motor on the RR Avon Mk 26 as fitted to our Australian Sabre aircraft and seeing I happened to be in the RAAF there was sometimes a bit of IPN laying around.......
For other reasons no nmodel plane use model rocketry really i would like to source the IPN fuel
Maybe you can enlighten me about the IPN fuel
I take it you filled a cartridge with the fuel placed that in a suitable holder in the engine compartment and ignited it to turn the motor over
This opens up the possibility a similar cartridge put into a rocket motor would send the model rocket upwards
Was the ignition source electrical or hammer action like a gun cartridge
Was the cartridge made form heavy steel or brass to take the forces and was the holder for the cartridge made from heavy metal types also
I don't want to find IPN has a tendency to ignite with certain metals like alu or similar and accidentally use the the wrong metal
Any ideas what class of HAZMAT this IPN stuff is for getting a gallon sent to me in the post or similar
or do you think the local big airport might have some to start up the old timer piston planes that pass through??
Is there a similar product with a trade name that is 80% to 90% IPN with a suitable 10 to 20% of something like methanol (Rubbing alcohol would be no good as it is 30% water ) that might be be less of a HAZMAT issue
There is near to no point for me to make a model rocket for 100% pure IPN if other modelers cant get the fuel easily so I prefer to stick to fuels that can be obtained
I suspect the concentrate is another stuff possibly nitro ethane
http://www.mind42.com/wiki/Nitroethane
as it is for helping Gasoline nitro methane fuel mix engines and IPN doesn't sound to be so useful for that purpose
but IPN might be very useful for glow motors
Heres an interesting list of which explains liquids in a different way and seems to have misunderstood what some chemicals purpose is in life
It also forgets Nitro benzene which has the shoe polish smell when it burns and is cancer forming to inhale the burning fume
http://www.mind42.com/wiki/Category:Liquid_explosives
Balsaeater
< Message edited by balsaeater -- 5/4/2008 9:30:56 AM >
       Post #: 8
RE: Concentrate for use with nitro??? - 5/4/2008 5:31:37 AM
downunder
Status: offline
IPN is a mono-propellant so it was simply pumped into a combustion chamber, ignited, and then the gas was passed through turbine blades similar to a turbocharger's turbine. This then drove through a gearbox to spin up the engine's compressor. Because the aircraft carried a tank of IPN this made it a multi-use starter. Other versions of the Avon used a cartridge starter (either single shot or triple) because the nose dome was quite accessible as on the Canberra bombers. The cartridge starter did the same thing as the IPN starter by sending massive amounts of gas through a turbine.
       Post #: 9
RE: Concentrate for use with nitro??? - 5/4/2008 9:29:17 AM
balsaeater
Status: online
Re:downunder thanks for the info on IPN
Now two things I want to figure about IPN
The first is how it compares to nitro methane as a Mono propellant
info on nitromethane here
quote:
ORIGINAL: www.mind42.com
Nitromethane can also be used as a monopropellant, i.e., a fuel that burns without added oxygen. The following equation describes this process:
4 CH3NO2 → 4 CO + 4 H2O + 2 H2 + 2 N2
which neglects to mention the extreme pressures needed
The advantage for me nitro methane is available on my doorstep
So the second thing I need to know is where I can buy IPN if I find that its mono propellant chemical features are superior so It would be interesting to see the chemical formulas and sales outlets
Also the separate issue is the original question what exactly s the concentrate stuff
balsaeater
< Message edited by balsaeater -- 5/4/2008 9:32:36 AM >
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
