Mspeed
Unfortunetly the slash is limited cause the tires are in the fenders, thats why I would not buy it as of right now. You cant put larger tires on the slash or they will not fit under the body. I would not have that limitation on the DT, you could put larger tires on it or wider. The nice thing about the slash is the racing without having wheel hangups. But until alot of people start getting them and they start making a special race class for them at tracks, I would feel limited where I could race it due to the lack of tire and clearance it would have. 3 and a half inches of ground clearance in the middle helps, but remember the tires are only like about 4.2 or so in inches diameter. That means where the control arms extend accross in the back and front its going to be real low to the ground.
_____________________________
Nothing to Prove, but if someone can figure out why my Jato will not work they are truly the best, I have tried everything.
