supertib
quote:
ORIGINAL: jaywax quote:
ORIGINAL: supertib quote:
ORIGINAL: marcus falconieri I just ran this motor for the first time (see my pictures if you want to see what it looks like) and this motor is crazy fast and smooth for a motor under $200. I collect motors and have about 20 from BOSS, CMB, FALCON, OPS, and all the popular ones so I know a good motor, and this is a good motor at any price! It's crazy that everyone who runs this motor says the same thing. It has great power, but is extremely smooth. It actually sounds smooth. I'm running the same engine and pipe. This is the most underrated engine on the market. its all great till the crank falls out of the motor.... STS =Junk That was a mature response. I know it was, i could have worded it better no doupt.. I have very bitter feelings towards STS motors and I feel I have more then ample reason to strongly advise people to stay away from them.......... They are a tainted fruit without question.. I agree with all of you that they can be sweet running motors with awesome performance... At one time I was selling STS motors by the dozens, modifying a whole pile as well... .21's, 28's and 30's....... At first all seemed great, the motors were solid and ran awesome.. But every time I ordered a batch of motors I started to see they were extremely inconsistent engines, with no 2 batches being the same... some cranks had 1 turbo scoop, others had 2 and some had 3... at one point it seemed as if the turbo scoops were put just any old place they would fit .. Some motors pistons were so looose the motor would not run, then other motors the piston is so tight the motor needs 3 gallons to break in.... Then all of a sudden people's motors started falling apart, dozens of motors failing, stock or modified the cranks just feel apart...... Management at STS could not give 2 poops either.........They just kept on sending out junk, throttle pulls guaranteed to strip, 50/50 chance of crank failure, 50/50 chance of poor piston fit, 50/50 bearing failure..... I ended up having to re-modify so dam many STS motors it makes me sick to my stomach....It didn't matter if the failures were my fault or not ( which they weren't) I would still re-modify the warranty replacement engines............. STS are junk, they are poorly designed and the company behind STS couldn't care less about the product and service they provide... Low buck Asian company preying off those who know no better............. for the $50.00 you save buying a STS its seriously not worth the fuel to break them in.... In all honsesty buy a Picco for $200.00 and you have a much superiro engine in all aspects A Picco will beat a STS every single time in every single way you can compare them other then price.....If buying some Taiwanese crap motor to save $50.00 is worth it to you then all the power to you...but I have walked the STS road much longer and much more in depth then any of you have, and I suggest strongly to stay clear !!!
