pilotpete2
VT, USA Status: offline
Hi tony, Sorry about the untranslated acronym , ESV stands for expanded scale voltmeter. I don't know what is available from your local distributors on your side of the pond, but here's a popular one from Tower Hobbies. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWW16&P=0 With one of these you first read the no load voltage and then see what it settles at under the simulated load. It seems that all the guys planes I see with the volt watch, dip into the red when you twiddle the sticks. It sure sounds as though you're doing all the right things with the batteries[)]. Here's a thought, the next time you fly, start with a full charge, then fly until the voltwatch makes you think you should stop, then when you get home put the battery on the cycler to discharge it and see how much capacity is left, probably a lot more than you think. Good luck, Pete
