eHawk 2000
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> eHawk 2000
Page: [1] 2   next >   >>
Login
eHawk 2000 - 5/3/2008 6:10:48 PM
pxr5
Status: offline
I just bought an eHawk 2000 glider and have been looking for a brushless/esc/prop upgrade that will work with my 11.1v 20c 2100mah and 1800mah lipo's I already have.
the threads on this glider with peoples recommendations are now outdated and their links no longer work.
Idlike to have enough power to climb vertically so i can pull out of trouble, and more than anything to help me get my head around how much power is needed for a given weight of glider.
Thanks everyone. id really apreciate your expert advice here.
       Post #: 1
RE: eHawk 2000 - 5/3/2008 9:10:35 PM
RU4JESUS2 FALCONGTS
Status: offline
IM in the same boat (the dreamline , f5j baby fly e)
you may want to go with E flight for mine its $$$$$$$$$$$ motor and esp 150 ( hacker 22-22L /spin 22 esp) have to wait on the spinner
E flight may bolt right in also
good luck
_____________________________
ON A WING AND A PRAYER!
(in reply to pxr5)
       Post #: 2
RE: eHawk 2000 - 5/3/2008 9:26:49 PM
pxr5
Status: offline
thanks bro, not sure i follow all those terms im a complete numbskull when it comes to all these numbers associated with motors.
i think i might just get the most powerful motor and esc i can buy and just go for it, its not as if im gonna be using the power all the time.
thanks mate
(in reply to RU4JESUS2 FALCONGTS)
       Post #: 3
RE: eHawk 2000 - 5/3/2008 9:31:41 PM
RU4JESUS2 FALCONGTS
Status: offline
NO problem im the same way try E flight ( www.E-flightRC .com) I forget who is local for you
let me know what you do
thanks falcon
(in reply to pxr5)
       Post #: 4
RE: eHawk 2000 - 5/3/2008 9:39:30 PM
pxr5
Status: offline
will do thanks.
you'd think with so many motors and esc's out there id have 100 options, but theres so many not even the experts can throw just one option at me, i get the feeling they are just as bewildered and there setups are trial and error. heck not even shops can advise me and they stock the damn things lol
       Post #: 5
RE: eHawk 2000 - 5/3/2008 10:01:54 PM
RU4JESUS2 FALCONGTS
Status: offline
try www.towerhobbies.com
they should have a chart to tell you what goes with what
well worth the time at this site
sorry i forgot this
(in reply to pxr5)
       Post #: 6
RE: eHawk 2000 - 5/3/2008 10:08:07 PM
RU4JESUS2 FALCONGTS
Status: offline
what size motor was it set up for??? if came with any
example (600 size motor) for 2m plane
I think the most you can get is a ( 400 or a 480 class motor /25 amp esp ) your plane may be to heavy for this set up im not sure
my 71" glider or 180 cm 1800 mm this will work all up weight is 20 0z to 24 oz
hope this helps
www.soaringusa.com E mail them if nothing else works I know they can help
< Message edited by RU4JESUS2 FALCONGTS -- 5/3/2008 10:27:31 PM >
       Post #: 7
RE: eHawk 2000 - 5/3/2008 10:24:36 PM
pxr5
Status: offline
thanks for that link looks quite helpful.
the motor that came with it is a 540 brushed motor. i dont intend on using it cos they burn out after just 40 flights and wont take my lipo's.
       Post #: 8
RE: eHawk 2000 - 5/3/2008 10:27:16 PM
pxr5
Status: offline
i believe this is its spec
Mtroniks - Purple Heat
540 size Mabuchi motor <font color=purple>Purple Heat</font>
This 27 Single, 540 sized Mabuchi motor comes complete with motor suppresion capacitors.
* Dimensions : L57.0mm, D36.0mm, Shaft diameter 3.17mm
* Voltage, 9.6V
* Off load current, 2.06A
* Max current, 51A
* RPM, 14000RPM
Code: PURPLEHEAT
Price £4.99
so far im thinking of gettin this but i havent got a clue if its a safe setup or if its powerful enough
EnErG Pro C35-14/1300 motor
11x6 or 11x7 prop
Tornado 40amp controller
i know this will handle my lipo's but thats it.
< Message edited by pxr5 -- 5/3/2008 10:33:49 PM >
(in reply to pxr5)
       Post #: 9
RE: eHawk 2000 - 5/3/2008 10:38:33 PM
RU4JESUS2 FALCONGTS
Status: offline
ouch I do not think your lipo will work with this plane because of weight
xx-xx-xxxx
the first number is can diameter ( mm)
the 2nd is can lenght (mm)
the 3rd is output rpm/v (kv)
your not alone i have a hanger 9 aspire same problem
(in reply to pxr5)
       Post #: 10
RE: eHawk 2000 - 5/3/2008 10:53:46 PM
pxr5
Status: offline
why do you say that? whats the problem, is it the 20c rating? need to be higher?
thanks for explaining those numbers!
< Message edited by pxr5 -- 5/3/2008 10:54:22 PM >
       Post #: 11
RE: eHawk 2000 - 5/3/2008 11:03:24 PM
RU4JESUS2 FALCONGTS
Status: offline
I not very smart may be that im stupid go to the thread here aspire rtf by hanger 9 they have lipo set ups plane is like yours hope this helps sorry if I made a mistake
(in reply to pxr5)
       Post #: 12
RE: eHawk 2000 - 5/3/2008 11:14:36 PM
pxr5
Status: offline
i read someone here with your plane said this
"I have a Phasor 30/3 with a 11.1 3200 LIPO pack. This is a direct drive with a 9 x6 prop. This set up will take up to the thermals in seconds. And I mean straight up. The down side is this set up cost some real money."
this link shoes a glider like mine, same size and weight (close enough) and down the bottom they show a brushless alternative and the lipo the suggest is 25c not 20c, if i knew my lipo would run that motor and esc id go with that.
http://www.modelflight.com.au/thunder_tiger/thunder_tiger_soaring_star.htm
< Message edited by pxr5 -- 5/3/2008 11:15:38 PM >
       Post #: 13
RE: eHawk 2000 - 5/3/2008 11:38:53 PM
RU4JESUS2 FALCONGTS
Status: offline
that is a sweet plane a club member has one he put an rc car brush motor in it and never had a problem i do not remember what he had
tower gpmg4600 35-30-1450 may work
esp ss 45 gpmm 1840 minimum lipo is 3 cell 2100 9x6 prop this may work i may be wrong
i do not know what else to say sorry
falcon
(in reply to pxr5)
       Post #: 14
RE: eHawk 2000 - 5/3/2008 11:51:51 PM
pxr5
Status: offline
it is nice, i would have got it if they wer
