Need help with a few summer fixes.
Tower Hobbies
Logged in as Guest
  Printable Version
FS Racing Monster Truck 4WD 1/5 Scale Blue - RTR
Seller:  pmwtrading
Details:   $755.00   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> Need help with a few summer fixes.
Page: [1]
Login
Need help with a few summer fixes. - 5/3/2008 6:43:08 PM
Narutoscryed
Status: offline
Well summer is almost here and my lst2 is still sitting crippled in my room. I need to get it fixed but so far i have only done more harm than good.
so far i have lost my manual that came with the car so i have nothing to go by for working on it. i hope to fix many MANY things on it.
First thing i have to fix is the thing i broke trying to find something else to fix. and that is the screws that hold the skid plate in. well long story short the screws that hold the skid plates in had stripped out heads.. so i could not remove the skid plates to get workin on the car. to remedy this i tried to drill out the heads.. so i could pull the skids off and then screw out the screw shafts with pliers well unfortunatly i drilled to far and now there is no way to get the threads outa the actual plastic side rails.. they are flat even ... I would really like some tips on fixing that..
then once i get that finished i need to purchase and install a new motor mount and i have no idea how to do that.
then finally once i get all that done i have to fix either my transmition, clutch. or some other thing that would keep a truck from moving when have it at a good throttle.
if i can get a camera i will upload some pics.
       Post #: 1
RE: Need help with a few summer fixes. - 5/3/2008 7:02:57 PM
BAJABANDIT
Status: offline
Wow thats a delima with the screws !!! LETS see !!! you could drill them out the rest of the way !! and re thread the holes! OR if they make them small enough buy extractors for the screws!
(in reply to Narutoscryed)
       Post #: 2
RE: Need help with a few summer fixes. - 5/4/2008 12:11:45 AM
full maxx
Status: offline
try a dremmel and slice a slit in the end of the screw and use a straight screw driver to remove it
_____________________________
check this out... www.trukz.com
(in reply to BAJABANDIT)
       Post #: 3
RE: Need help with a few summer fixes. - 5/4/2008 12:24:13 AM
CBM Racing
Status: offline
Or get new side rails, and be more carefull next time . As for motor mounts, you don't need to remove anything, just 4 screws from bottom and engine/mounts come out all together. The truck not moving when giving it throttle is most likely the one way bearing in the 2 speed. It will be inside the biggest(1st)plastic gear housing. Good luck with it all!
MMmm..Piepants..
(in reply to full maxx)
       Post #: 4
RE: Need help with a few summer fixes. - 5/4/2008 1:57:13 AM
str8jailbird
Status: offline
If you lost your manual check out the Team Losi site and got to vehicles. Check out the LST2 and download the manual and all of the exploded views you want for free. Either save them to your computer or print them up.. EASY
(in reply to CBM Racing)
       Post #: 5
RE: Need help with a few summer fixes. - 5/8/2008 2:32:17 AM
capt473
Status: offline
Go to sears and buy a set of screw extractor bits for your drill. You basically drill a small hole in the end of the screw, insert the other end of the screw extractor into the hole with the drill in reverse and the screw extractor threads itself in backwards and then it backs the screw out. viola....
       Post #: 6
RE: Need help with a few summer fixes. - 5/8/2008 5:46:47 AM
KRO
Status: offline
This is your best bet ...
RC18 MT , MGT 4.6SE , REVO , Trinity NOW ,
JATO 3.3 , LST2 , Mini T , Micro T , MLST2 , E-REVO
(in reply to capt473)
       Post #: 7
RE: Need help with a few summer fixes. - 5/14/2008 3:53:12 PM
bjhe333
Status: offline
No one said buy a screw kit from Hex screws and worry about stripping screws no more. Best 20 bucks I spent
http://www.killerhobbies.com/items/losi/losi-lst-trucks/hexcrews-lst-trucks-hop-ups/hexcrews-lst2-hexheads-screw-conversion-kit-hexlsls2-0107-hexlsls2-0107-detail.htm
sorry 38 bucks
< Message edited by bjhe333 -- 5/14/2008 3:54:17 PM >
I Love Whole life insurance and My LST
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
