Lipo Balanacer
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  4/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Lipo Balanacer
Page: [1]
Login
Lipo Balanacer - 5/3/2008 10:53:59 PM
Calin666
Status: online
I was wondering if anybody could suggest a good lipo balancer for not too much, maybe around $40 or so, if such a thing exists.
I will be running lipo's in a 1/10 buggy only.
       Post #: 1
RE: Lipo Balanacer - 5/4/2008 1:27:31 AM
jeeprubicon2k3
Status: offline
http://www.maxamps.com/MA-Method-Balancer.htm
Maxamps Method Balancer, A++
(in reply to Calin666)
       Post #: 2
RE: Lipo Balanacer - 5/4/2008 3:18:47 AM
nonstoprc
Status: offline
Blinky balancer is quite good. $23 from tower hobbies.
(in reply to jeeprubicon2k3)
       Post #: 3
RE: Lipo Balanacer - 5/4/2008 8:52:46 AM
jasonwang3a
Status: offline
http://www.bphobbies.com/view.asp?id=B3615204&pid=B3615200 $29.95
2S to 6S cell balancer, automatically cut off the charge circuit when detecting any cell voltage over 4.25V.
_____________________________
Jason
(in reply to nonstoprc)
       Post #: 4
RE: Lipo Balanacer - 5/4/2008 3:04:38 PM
BigTb17
Status: offline
Are you looking for just a balancer, or a balance charger?
None of the balancers listed will charge a LiPo, only balance them. With every balancer listed you will still need a charger. It will probably be difficult to find a good balance charger for $40.
However if you already have a charger any of those balancers should work fine. The blinky is probably the cheapest balancer you will find that is decent. It will balance the batteries, but cannot be hooked in-line with a charger. The others can be used to alone to balance, or can be connected to a charger to balance while charging. The Equinox balancer is what I use and it works well. It is probably very similar to the two posted above at maxamps and bphobbies.
(in reply to jasonwang3a)
       Post #: 5
RE: Lipo Balanacer - 5/4/2008 7:09:04 PM
Calin666
Status: online
Thanks for the info!
I have a Multiplex charger already so, I just need the balancer. HAveing one that hooks in-line, is pretty much what I was thinking about.
Those suggestions all give me los to think about, and look at.
Once again, thans!
(in reply to BigTb17)
       Post #: 6
RE: Lipo Balanacer - 5/4/2008 9:48:04 PM
nonstoprc
Status: offline
I have used Blinky balancers for my lipos and A123s (they are different). They actually can be used during charging.
My TunderPower lipos come with a balancing connector. So with an adaptor, it is possible to connect the balancer to the lipo through the balancing connector. THe battery is balanced live during the chargind.
For my 2cell A123 receiver/ignition packs, I used th MPI charging switch. Because it has a third wire in addition to the red and black wire, it is possible to hook the middle wire on the pack to the third wire to allow in-line charging. The third wire on the switch that lead to the receiver should be cut though.
       Post #: 7
RE: Lipo Balanacer - 5/5/2008 1:27:27 AM
BobMaine
Status: offline
quote:
ORIGINAL: nonstoprc
Some "Blinkey" balancers don't have reverse polarity protection connect it backwards and your Blinkey will blink no more. Buy an Equinox.
I crewed on USAF cargo planes so long ago we worried about bird strikes from the rear...
       Post #: 8
RE: Lipo Balanacer - 5/10/2008 12:59:25 AM
DARKWAV
Status: offline
The new maxamps balancer looks pretty nice, and you can push a lot of amps through it for in-line charging/discharging. Also if you have an assortment of batteries with different balance connectors looks like they have a good adapter selection available for purchase.
My only LiPo has an Align style balance connector so it works with the Equinox right out of the box. For $29 I think it is a great price, but you can only run 3A through it max. An extra $20 gets you a high power adapter set good up to 6 Amps. The nice thing about these adapters is that you use it in place of the harness that came with the Equinox, so you're not daisy-chaining a bunch of stuff. For a Multiplex charger the Equinox sounds like it would be a pretty good match.
If you need to purchase adapters to work with your batteries balance connectors you'll need to factor the price of those into the equation.
HPI E-Firestorm 10T / HPI E-Savage / Tamiya TamTech-Gear GB-01
       Post #: 9
RE: Lipo Balanacer - 5/10/2008 7:21:46 PM
Slarti
Status: offline
Sorry for the newb questions, but I have a few. I have two types of batteries that I will be charging with an Orbit Microlader. One is from Hobby-Lobby. It is a 11.1 V 800 mAh "Enerland Twenty (20C). IT says it is a 3S so I am assuming that it is a 3 cell battery. The other batteries are e-flight EFLB0995 3 cell 11.1 v 800 mAh. These both have different balancing connectors. One (the hobby lobby) has a five pin connector, the other (e-flight) has a four pin connector. (Note: The five pin connector only has four wires going to it.).
My questions are as follows:
1. Do all balancers have ports for the four and five pin jacks?
2. Do I need a specific balancer for the Obrit or are all balancers charger netrual
3. I'd like to get a balancer that will balance "in-line" while the batteries are charging, is there a specific balancer that will do this better than others?
Thanks for the help.
Mark
(in reply to DARKWAV)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
