Whats wrong with my Blackhawk 500 SE Pro Continued....-)
Tower Hobbies
Logged in as Guest
  Printable Version
Align T-REX 450SA ARF
Seller:  Erick Royer
Details:   $150.00   |  6/13/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Whats wrong with my Blackhawk 500 SE Pro Continued....-)
Page: [1]
Login
Whats wrong with my Blackhawk 500 SE Pro Continued....-) - 5/4/2008 12:18:56 AM
ginnz
Status: offline
ok, a week or so ago i posted a problem with my BH 500, and it kinda sorted itself out, it seems.
it basically all started after a crash which broke my mainshaft. at he time of replacing the mainshaft, i aso upgraded to a CF boom. the aluminum one had a minor blade strike in it that the previous owner put in it....
anyways, for the last 2 weeks the wind here has been rediculous, as normal for spring where i live. today i had the chance to fly this morning. i put 4-5 packs through the BH and notice that my cyclic isnt what it should be. its more sensitive going to the right (tail in), and any drift to the left almost takes full stick movement. its not drifting, but when i give it right cyclic, only minor inputs are needed to get it to do what i want, but left seems retarded as it seems. the swash is level, and putting it on the bench, the swash seems to have equal movement between left/right input.
why then would it be so non responsive to left input? i have all the ball links on the outer most positions on the head for maximum throw, and my blade tracking is good. (ive got -2 degrees at low stick)
everything seems normal for setup from what i know. its really bugging me. as it didnt seem like this before. it was snappy in all orientations.
anyone have any idea's?
TIA
Ginnz.
       Post #: 1
RE: Whats wrong with my Blackhawk 500 SE Pro Continued... - 5/4/2008 5:28:56 AM
srouthouse
Status: offline
dumb question but are you running expo? and how,s your travel set?
(in reply to ginnz)
       Post #: 2
RE: Whats wrong with my Blackhawk 500 SE Pro Continued... - 5/4/2008 3:20:47 PM
ginnz
Status: offline
no expo.
and my travel's are all set to 100%, i didnt change anything since i first set it up. except the pitch servo, but thats all fine. oh, but i did change all mixing from 60% (for all 3) to 55%....
UPDATE:
i increased my travel on the aileron to 120%, and the swash mix back to 60% on all, it seems alot better.....
i wish i could get the settings others are using on their BH 500's with the spektrum system.
and off topic, has anyone ever added a longer tail boom to the BH500 with a longer belt, of course and tried longer blades? i was just wondering, with a longer boom and longer blades running 2200MaH 4s packs, what it would perform like...?
< Message edited by ginnz -- 5/4/2008 10:28:44 PM >
(in reply to srouthouse)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
