OS 1.20AX clicking noise
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  7/13/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> OS 1.20AX clicking noise
Page: [1]
Login
OS 1.20AX clicking noise - 5/4/2008 2:25:57 AM
flygilmore
Status: offline
Wanted to put this out there since my nephew and I just started breaking in his new 1.20AX. Anyway, after 4 tanks through the motor (which ran perfect by the way) we noticed a loud clicking when back flipping the prop to compression. To me, it sounds like the connecting rod where it has some play (and the fact that the prop is turned clockwise looking from the front) and perhaps it is something that will go away with more run time. Anyone experience this loud click when turning the motor reverse and hitting the compression stroke???
Thanks!!!
_____________________________
I didn''t choose Mojo, Mojo chose me PRO BRO #1963
       Post #: 1
RE: OS 1.20AX clicking noise - 5/4/2008 9:18:48 AM
liquid_TR
Status: offline
Yes, I have.. I noticed it while I was playing with the prop back and forth at home, when the engine was at rest on the plane.
It went away after I put some oil thru the glow plug hole to wet the cylinder wall and ring.
I didnt made that noise when flipped forward, it did it when flipped backwards only.
I assumed the cylinder wall got too dry, so I oiled it. I never heard that sound again.
LiQuid TR
(in reply to flygilmore)
       Post #: 2
RE: OS 1.20AX clicking noise - 5/4/2008 11:41:07 AM
flygilmore
Status: offline
Yes, that is how his does-only makes the loud click when flipped backwards. I think it is something with the connecting rod and where it is at teh top/bottom of its cycle and there is a bit of play in it. When turning the motor in the correct position, it doesn't make any noises and is a smooth as can be which leads me to believe that there is nothing wrong along with the fact that it is one fine running engine!!!!
Thanks for your input-any one else have this experience??
(in reply to liquid_TR)
       Post #: 3
RE: OS 1.20AX clicking noise - 5/4/2008 10:28:04 PM
XJet
Status: offline
Check the crankshaft for any radial (side to side) and axial (back and forth) movement.
It's possible that your engine shipped with faulty bearings (it happens sometimes) and I've seen some very weird symptoms produced by such bad bearings.
There should be no perceptible movement in the crankshaft if you hold the prop tips and rock them back and forth or push/pull on the prop hub.
When I'm not here, I'm at RCModelReviews
       Post #: 4
RE: OS 1.20AX clicking noise - 5/5/2008 1:30:53 AM
N1EDM
Status: offline
I had a Magnum 91 that did that (consider it a OS clone). I tore the engine down and everything was perfect. My conclusion is that this is the ABC piston sticking to the top of the cylinder sleeve because the engine is brand new.
I'm not sure if I'm right or not, but I'm pretty confident in my analysis. Can't explain why this does it for you when backflipping, but not when running in the correct rotation.
Bob
An expert is someone who has been doing it for 15 minutes longer than you.
(in reply to XJet)
       Post #: 5
RE: OS 1.20AX clicking noise - 5/5/2008 4:05:04 PM
Bax
Status: offline
With many larger-bore two-stroke engines, you'll hear such a clicking sound. It's usually the ring striking the upper lip of one of the ports. This happens when flipping backwards because the loads are placed in a different direction than when the engine is flipped forward or is running forward. This is not a thing to be concerned about, it's very, very common.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to N1EDM)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
