RES vs. Full House - Which is better for Thermal Duration Soaring?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> RES vs. Full House - Which is better for Thermal Duration Soaring?
Page: [1]
Login
RES vs. Full House - Which is better for Thermal Durati... - 5/4/2008 2:56:32 PM
aeajr
Status: offline
Which is better for thermal duration spoot soaring and which is better for
unlimted contest soaring, RES or Full House? What's your preference? What's
your opinion?
I started on a 2M Spirit RES and then on to a 2M Sagitta 600 RES. I loved them
then and I love them now.
RES was so easy to fly and a simple 3 channel radio was all I needed. Later,
an entry level computer radio allowed me to add spoiler to elevator mixing to
automatically avoid the nose dive that is common on RES planes when you deploy
the spoilers. Fantastic! I could sky them out and I could land them
pretty accurately. What could be better?
To me RES = Simplicity, easy flying and low cost. A great combination! But
this just for beginners, right? )
I added a string of full house planes. First was an Airtronics Legend which was
my full house trainer. This ship is heavy and it took a beating but I learned.
Then came a Polecat Thermal Dancer and now a Kennedy Composites Supra. The
Thermal Dancer is a joy and the Supra is amazing. But I needed to add a much
more costly and flexible computer radio to fully take advantage of what a full
house sailplane can do. The Futaba 9C Super is now my main system.
To me Full House = Flexibility, but with much more complexity and at a higher
cost. A great soaring experience is the result, especially for contest flying.
Following this journey, I had RES as the beginner stuff and full house as the
goal. THEN I BOUGHT AN AVA. Oh my goodness, what a wonderful soaring
machine. Incredibly simple to fly, and it will float on the lightest lift.
The stability of the plane gives you even greater confidence to venture out out
out to the edges because the plane will naturally want to stay level. I told
one of my buddies that thermal soaring with an AVA is almost like cheating it is
so easy to fly and to sky this plane out. RES is not just for beginners any
more ... for sure!
But the AVA is not the only great RES sailplane. There are many other great
wood and composite RES planes. From reading the forums I read rave reviews
about the Skybench Bird series and the Skybench Olly as well as the MMGlidertech
Marauder. These are just a few wood based RES planes that come to mind that
people seem to rave about.
Before I bought the AVA I researched the Topaz and the Soprano as well. These
and other composite RES palnes also seem to have tremendous followings. Now I
know why.
And let's not forget Mark Drela's Bubble Dancer that started this whole new
generation of RES planes. The Bubble Dancer became the prototype for the AVA
and the others like it. These go well beyond those first beginner RES planes.
I have seen people fly these against full house ships in ESL and other
competitions.
So, now I have this dilemma. When I go to the field, what do I want to fly
full house or RES? And as I look toward this year's Eastern Soaring League
contest schedule, do I opt for complexity and flexibility, or do I opt for
simplicity and ease of flying that lets me focus more on the air and less on the
plane and the mixes.
Oh, what a delicious dilemma. )
So, what's your opinion on RES vs. Full House for sport and unlimited contest
flying? Everyone's opinion is valid. No one is wrong.
Let the conversation begin!
_____________________________
Clear Skies and Safe Flying!
Ed Anderson
Moderator
Park Pilot Program Partner
       Post #: 1
RE: RES vs. Full House - Which is better for Thermal Du... - 5/4/2008 3:36:11 PM
fishguide
Status: offline
Nice post. I have considerable experience with Soaring, but have been inactive for nearly 23 years. I am back in now and was looking for a plane. I looked at all of them including the Supra. Since it has been so long away from the hobby. I decided on the AVA, because I consider myself a beginner again. I bought the flap version just for grins. I hope to be flying it very soon and be playing with flap - elevator mixing. Your post excited me about the AVA.
Bob Summers
LSF 3548
(in reply to aeajr)
       Post #: 2
RE: RES vs. Full House - Which is better for Thermal D... - 5/6/2008 7:21:21 AM
marc 540
Status: offline
Ed,
I'm new to glider's and was wondering if you could explain what RES and AVA stands for? I think I know what "full house" means. Right now Im flying a BOT and I just ordered an Xmodels whisper with aileron's only. can I use spoileron's or flaperon's to slow it down? Also it has a V-tail and I was wondering if I should set it up for elevator and rudder or just elevator?
Thanks' Marc 540
< Message edited by marc 540 -- 5/6/2008 7:23:07 AM >
(in reply to fishguide)
       Post #: 3
RE: RES vs. Full House - Which is better for Thermal D... - 5/6/2008 11:09:10 AM
aeajr
Status: offline
Marc,
Welcome to the wonders of thermal duration soaring. This has become my passion, so I am happy to help.
AVA is the name of a high end competition grade Rudder/Elevator/Spoiler sailplane, RES.
http://www.kennedycomposites.com/ava.htm
In simple terms, spoilers are designed to spoil the lift of your wings so help you settle your glider down for landing. They can also be helpful in getting the plane out of strong thermals.
If you are going to fly the Wisper for thermal duration soaring, then definately set up for rudder and elevator. Rudder should be the primary control you use on your hi-start or winch launches. Much more effective in controlling the plane for good launches than the ailerons.
TD pilots love the rudder as it help coordinate turns for low drag efficent thermal turns. And if you ever work on spot landing, rudder is extremely valuable, especially when you are working close to the ground.
Ed Anderson
Moderator
(in reply to marc 540)
       Post #: 4
RE: RES vs. Full House - Which is better for Thermal Du... - 5/6/2008 11:19:05 AM
aeajr
Status: offline
quote:
ORIGINAL: fishguide
Bob Summers
LSF 3548
Welcome back to soaring. You are going to love that AVA. The AVA is wonderful.
My one bit of advice is to be sure and install a ballast tube. In winds under about 5 mph, this plane floats and thermal so well it is almost like cheating. I just lov it.
However as the wind starts to rise, the light weight means it does not penetrate as well and can get bounced around. It ie certainly flyable and my do OK up to 10 mph but if you put in some ballast it flies even better. I have been experimenting with mine. many AVA pilots fly with 4-6 ounces in the plane in all but the mildest condtions. You can probably achieve that just by stuffing some weight in the space under the wings.
I have a 44 ounce AVA that has a landing skeg, ballast tube and modified spoiler that has been split into two. I have only had it a few weeks but in that time, I have come to love the plane, but in gusty conditions it flies better with some ballast.
I have a 9 ounce slug for it now, about 20% ballast. I am hopeful I can stuff about 16 ounces into it, between the ballast tube and the space under the wings. That would be for windy conditions, say over 15 mph.
Ed Anderson
Moderator
       Post #: 5
RE: RES vs. Full House - Which is better for Thermal Du... - 5/7/2008 6:01:06 PM
ChipG
Status: offline
Great thread. I too have been out of competative soaring for about 20 years. I have been looking to get back into the field and am trying to decide what to fly.
What really amazez me is that the Dodgson Windsong in my basement was a full function...rudder, elev, aileron, flap and spoiler......all mechanically mixed and did it all with a 4 channel radio with a couple of push buttons added.
I don't think I can even get the batteries for all my old gear...Pitty
Chip Gibbs
(in reply to aeajr)
       Post #: 6
RE: RES vs. Full House - Which is better for Thermal D... - 5/7/2008 9:45:56 PM
aeajr
Status: offline
So, Chip,
When will you be back in the air and what do you plan to fly? Get the Windsong out, put in some modern electroncis and get it into the air.
Ed Anderson
Moderator
(in reply to ChipG)
       Post #: 7
RE: RES vs. Full House - Which is better for Thermal D... - 5/8/2008 1:18:33 AM
ChipG
Status: offline
I was kinda lookin at the DLGs. I always enjoyed flying the larger models but, you really need some flying buddies to make a winch worth it. Also, the closest club is CASA in Maryland which is a problem even on weekends with the traffic in the DC area.
On the DLGs, it seems like most of the top competitors are ARF, what happened to the builders ? You can't get the same since of pride flying something built by someone else.
aeajr, I hope to come up with a choice pretty soon....seeing the buzzards climb is just pissn me off
Chip Gibbs
Anybody soaring in northern Virginia ?
(in reply to aeajr)
       Post #: 8
RE: RES vs. Full House - Which is better for Thermal D... - 5/8/2008 3:03:35 AM
aeajr
Status: offline
quote:
ORIGINAL: ChipG
Chip Gibbs
No problem building, just learn how to bag a wing.
Now, this thread is about RES vs Full house. You don't typically see either in DLGs. They are either R/E or A/E/R with no flaps.
Ed Anderson
Moderator
(in reply to ChipG)
       Post #: 9
RE: RES vs. Full House - Which is better for Thermal D... - 5/8/2008 3:30:00 AM
aeajr
Status: offline
How much spoiler should you use?
Spoilers are like any other surface. You use what you need, when you need it. This may be influenced by the limitations of your transmitter and your ability to control the drop of the nose with elevator compensation.
I have my spoilers set up on a side slider on my Futaba 9C. I do that consistently across all my RES planes so they are always in the same place. My spoiler deployment is variable and has elevator compensation mixed in.
Once I am lined up to land and feel I need to start to lose some altitude I will add somewhere between 1/4 and 1/2 of my spoilers depending on my speed and height. When I want to drop it now I will add the rest, but only if I need it.
If I have managed my energy carefully I may not need spoilers at all. I just glide it in. I don't use spoilers on every landing, just when I need them.
Max Spoiler Amount
At full deployment on my Spirit they hit about 60 degrees. On my Sagitta about the same. Both are 2M planes with spoilers right behind the spar. Both get elevator compensation. The Spirit only needs a little, maybe 10%. The Sagitta needs much more, maybe 40%.
On the AVA, they go up about to about a 45 degree angle. These are in the mid section. Normally the AVA has one big spoiler but mine has split spoilers which means less spoiler surface but more air to the tail to help me maintain control at slow speeds. Everything is a compromise.
With that setting, at max, I think I have about 50% elevator mixed in. Seems to work just fine.
Nothing wrong with having an option for 90 degrees but it depends on the plane as whether you will ever need it. 90 degree spoilers would be full stop, war emergency, stand on the brake pedal for most RES planes. The drag, loss of speed and dive would be pretty severe on many planes. But if you have very small spoilers you may want this.
90 degree spoilers might be useful getting out of a super thermal but I don't need that to land with my planes. The plane would lose speed and drop like a rock very quickly. However if you practice with it, that is fine, especially if you can apply less.
Radio controls
Some radios may only give you three positions, closed, half and full. While that may seem quite limiting, if you practice with it, that should be enough control for all but the most precise work. In fact some people refer the 3 way switch because the response is known and consistent.
Even though I have fully variable spoilers that is probably how I use them anyway. The variability just lets me ease them in, but I have a half way stop on my slider. If you practice with those settings you will know how to use them and that should be enough control.
Spoilers vs Flaps
One advantage of spoilers over flaps is that they raise the stall speed, the plane will stall at higher speeds. If you slow too much you can retract them and the lift of the wing will increase and the plane will continue to fly. In this respect they are more forgiving than flaps.
With flaps you decrease the stall speed so you can slow the plane way down and keep flying. But if you slow down too much, pulling the flaps in increses the stall speed and you may not have enough speed to keep flying. So, if apply too much flap, then retract them, you may stall and drop. And if you do this at 30 feet you may not have enough room to pick up speed to reach flying speed again. That is where the ground comes to your unwelcome rescue, or you would fall forever.
I have tested this theory more times than I care to remember, unintentionally. It holds true every time. In my early full house experience I proved this over and over. My Legend has the scars to show for it. Combine this error with a high wing loading plane and you have a wonderful lesson plan for learning to repair wings and fuselages.
Net net, once you have flaps out and the plane slows, you may not be able to safely retract them. This situation does not exist on a RES plane.
Ed Anderson
Moderator
(in reply to aeajr)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
