Differences between Mamba 25, Sidewinder Micro, and Micro Pro Combo sets
AB, CANADA
Hey,
I was wondering what are the differences between ESC's. I know that the Mamba 25 is discontinued so I am trying to find one that the same or better then that one. Would I be better going with the Micro Pro or the Sidewinder Micro with a 6800kv motor. What are the differences between them.
VA
RE: Differences between Mamba 25, Sidewinder Micro, and Micro Pro Combo sets
From the looks of things the Micro Sidewinder is the same as the later 25's, and the Micro pro, is the Micro sidewinder with a case and heatsink. I have seen pictures with the case off the MMP, and it looks to be the same.
here are the pics thetable is referring to. This is my de-cased MMP next to my burnt mamba 25
if you don't mind not having a case, then go for the sidewinder. You can easily add your own heat sink, just buy the following
http://www.radioshack.com/product/in...entPage=family
Banned
Since the sidewinder and pro are so new to the market, and literally no one has any real experience with them, why don't you contact Mamba directly and ask them ???
IL
WOW ! That Mamba 25 is TOAST ! Did you try to run a 4s on it ?
If Novak's new min brushless system is decent then the Mongoose might end up eating the snake ! [X(]
ORIGINAL: KRO
http://www.youtube.com/watch?v=Wphcm8Xx_bs
The Mongoose looks nice, but if your not racing competitively, but just bashing, a Mamba or Quark will suit you fine. The Quark is great for bashing and high speed runs. The Mamba is good for those too, but only handles 3S max under warranty.
The thing the mamba has over the Quark is customer service/support. Email Quark at [email protected] or [email protected] . Then contact castle at [email protected]
See who contacts you first. I'll put my money on Castle!
CT
from what i've heard the pro handles 30 or 35 amps continuous vs the 25 amp sidewinder....but don't quote me. and the sidewinder replaced the mamba 25. if it were me, for the pretty small price difference, i'd go with the pro, just for the simple fact that if you want it to, it'll handle more power. i'm running the mamba 25 and i've got no complaints, works great. and i'd recommend it, but like i said, for the price difference why not just upgrade a little?
ORIGINAL: hollylx88
I know this because the older mamba 25s have lots of fets(I think there are 16 fets from pics I've seen when the sticker label is removed). In the pics I've posted, you can see the layout's are the same. There are 3 fets are on each side with the manufacturer number on top of each. I googled them and found the PDF spec sheet reading a current rating of 35amps continuous on it. The fet model is the same on the micro pro and my newer version mamba 25.
IL
Of course I did! I just use the micro pro on 3S max now. For 4S, I use the Quark
I've heard rumors that Sky Technologies is out of business ?
ORIGINAL: KRO
