ArtesJet 3000 Eagle TJT
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> TJT Turbine Direct Support >> ArtesJet 3000 Eagle TJT
Page: [1]
Login
ArtesJet 3000 Eagle TJT - 5/5/2008 12:36:44 AM
czech89
Status: offline
Is the ArtesJet 3000 Eagle the same as the TJT 3000? It says tjt.bz on the right side of the glow plug. I purchased this engine used a couple years ago. I believe it is circa 2001-2002? I just recently pulled it out of the boneyard and ran it on a test stand. It ran OK a couple times with very high EGT 780C. Now it will not accelerate past 110K rpm. I tried a different ECU with no help. I tore the egine down to investigate and found a small corner missing out of just one of the diffuser vanes and the inner ring of the combustion chamber has a blowout in it. The chamber is a newer 12 stick vs the older 6 stick design.
Can anyone service this engine or sell me a servicable combustion chamber?
Thanks in advance for any info or help!
Terry
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: ArtesJet 3000 Eagle TJT - 5/22/2008 7:15:11 AM
JET FX
Status: offline
Hi Terry, Iam not sure about internal component compatibility of your engine other than to say it appears to of originated from Artes circa 2001-02 I would say. Artes produced the blue canned version not TJT. TJT manufactured and supplied some components for Artes hence the similar appearance to the TJT. I would suggest contacting Artes Jets to see if they can assist you further or even Jet Central as they took over the production of the Artes line and might be able to service this engine. The JF-120 chamber and diffuser "maybe also adaptable" its worth a phone call or email to either to find out. The Jet Central/Artes JF-120 FADEC ECU will would for this engine, you can contact Gaspar directly for FADEC supply if need be also...
hope this helps
< Message edited by JET FX -- 5/22/2008 7:20:41 AM >
_____________________________
JET FX Australia~ Cosmic Pilots, Jets Munt, Yellow Aircraft, Sis-T, Fei Bao, Fly Eagle Jet, Wren- www.jetfx.net
(in reply to czech89)
       Post #: 2
RE: ArtesJet 3000 Eagle TJT - 7/25/2008 1:29:27 PM
josecilurzo
Status: offline
Hi Terry,
we had one that, and, we had many problems with fadec and the engine, but, a friend from Brazil change the original FADEC, to a new FADEC full auto start, and the engine runs ok, if you need help, call call for him in my name : gomes_se@terra.com.br
jose
       Post #: 3
RE: ArtesJet 3000 Eagle TJT - 7/25/2008 11:29:18 PM
scraper
Status: offline
Contact I-JETS, you may have to use your existing fuel ring but the chamber will fit straight in.
(in reply to josecilurzo)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU1
