Thank you guys !!! First I have to finish the Dragon Lady 90-120 from ModelTech and Spitfire (2030mm wingsp and 1.80 FS from Hot-hobby.com), I must do it for my reach friend, but now I can order the OS 1.20FS [:)] Best regards Peter
albert burton -> RE: Ultimate 120 (5/21/2008 1:00:17 AM)
Rod, That is good news about you 120 Ultimate. I have one also. I just started putting it together. I'm putting a 26cc gas engine in mine. I always wanted a plane that can go vertical all the way and I'm sure this combo will do it. Will post pictures when I finish it. I don't have the wheel pants, not in box. Hopefully NitroPlanes will send me a set. Happy flying.
Al
albert burton -> RE: Ultimate 120 (5/21/2008 1:16:41 AM)
I am putting a XYZ 26cc gas engine in my 12 Ultimate. I do believe it should be ok since you have a BME 26cc that worked out great for you. I should have mine ready in June.
Al
albert burton -> RE: Ultimate 120 (5/21/2008 1:20:52 AM)
RR24,
Who was the manufacturer of your engine? I'm putting a XYZ 26cc in my Ultimate. I hope I have plenty of power. What prop did you put on the engine?
Al
RR24 -> RE: Ultimate 120 (5/21/2008 3:50:37 AM)
I have the SPE-BCMA 26cc, i think it is simular to your, i had a 17x8 and 17x6 on it, didnt like the 17x6, was better with the 17x8
After reading the positive posts about this plane, I placed my order this morning for one. I've got an MVVS 26cc that I plan to put on it; and then shorten the tuned pipe so I can use an APC 16x8 prop. Hopefully, I can get it together quickly after it arrives and get in some great flying time in late August or early September.
