magnum 160 twin questions.
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  5/19/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> magnum 160 twin questions.
Page: [1]
Login
magnum 160 twin questions. - 5/5/2008 3:25:14 AM
jeff naul
Status: offline
my 160 twin constantly runs fuel out of the carburator when the engine is not running. any ideas of what to do to stop it? thank's fellas, jeff
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: magnum 160 twin questions. - 5/5/2008 6:10:45 AM
mike109
Status: online
I would think that the only way that could happen would be if the tank is too high relative to the carby. If the fuel level in the tank is much higher than the carby, the fuel will just syphon out once the fuel line is primed. Does this help?
_____________________________
If it''s not right on the ground - it won''t get better in the air. Club Saito # 597
(in reply to jeff naul)
       Post #: 2
RE: magnum 160 twin questions. - 5/5/2008 2:39:03 PM
jeff naul
Status: offline
mike, the tank is higher than the carb, for one i built the tank and it is up in the nose like the real cub and the twin engine has a bottom mounted carb. i was wondering if i have something on the carb set up wrong? it did this on the last plane that the engine was on but i didn't bother because the plane went down on the maiden. with the bottom mounted carb its hard for this not to happen on any plane. thank's jeff
(in reply to mike109)
       Post #: 3
RE: magnum 160 twin questions. - 5/5/2008 4:10:01 PM
LeeHop
Status: offline
Jeff -
Maybe a Cline regulator would help.Cline website
       Post #: 4
RE: magnum 160 twin questions. - 5/5/2008 6:39:30 PM
jeff naul
Status: offline
thank's for the link, looks like that will be what i need. i called them and tried to order but had to leave a message, i hope i can have it by the weekend because i'm going to a cub fly-in this weekend. jeff
(in reply to LeeHop)
       Post #: 5
RE: magnum 160 twin questions. - 5/5/2008 8:32:03 PM
Gringo Flyer
Status: offline
I have the same thing happen on a st90. The tank is a hair higher than the carb and when the tank is full it is high enough to siphon a little out. Generally I just fill up and then fly rather than letting it sit.
Also, if the carb is all the way closed it seems to siphon a lot slower.
"Courage is being scared to death...and saddling up anyway."---John Wayne
       Post #: 6
RE: magnum 160 twin questions. - 5/6/2008 12:36:49 AM
PlaneKrazee
Status: offline
The Cline is the way to go. With it you shouldn't need on board glow either. I've used them on two twins with good results. First start of the day will require good priming.
KB1DTB
AMA11123
(in reply to Gringo Flyer)
       Post #: 7
RE: magnum 160 twin questions. - 5/6/2008 12:51:37 AM
jeff naul
Status: offline
thank's guy's, they called back today and it will be on the way in the morning. next question is do you put the fuel filler before the regulator? jeff.
(in reply to PlaneKrazee)
       Post #: 8
RE: magnum 160 twin questions. - 5/6/2008 10:31:05 PM
PlaneKrazee
Status: offline
yes
KB1DTB
AMA11123
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU1
