BoysToys
CA, USA Status: offline
I saw those lipos on ebay and was thinking about buying a couple of them. Let us know how they hold up after you get some cycles on them. I am trying not to buy any hobby stuff this month and attemting to save for a new plane right now so extra packs for the 500 are on the back burner. I want a plane that I can hover like along with my heli! My 500 is setup with the stock Align motor and Esc, 3 Hitech HS-5245mg digital servos on the swash, Futaba Gy401 gyro, Futaba S9257 tail servo, AR6200 receiver, and a Dimension Engineering SportBec. If I was building again I would most likely use Futaba S9650s on the swash and just replace the gears. My Hitecs don't strip gears but the case is prone to breaking inside during a crash. I hear Hitec recently redesigned them but have not seen a new model to check for any differences. You can also use JR servos, I think they are the Z3650s but am not sure. I am also running some of the new Align metal bling (main bearing blocks, tail case, tail slider, mixing arms) but none of it is necessary. I just like the way it looks. Download the Finless videos and your 500 will go together without a hitch.
< Message edited by BoysToys -- 5/8/2008 4:51:50 AM >
_____________________________
T-Rex 500CF~T-Rex 450SE V2~3DHS Extra 300 SHP~Extra Stiffy~E-Flite Mini Pulse XT~Parkzone T-28 Tojan~GWS Slow Stick
