CoolPower 15% Heli vs CoolPower 15% 4-stroke
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  4/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> CoolPower 15% Heli vs CoolPower 15% 4-stroke
Page: [1]
Login
CoolPower 15% Heli vs CoolPower 15% 4-stroke - 5/6/2008 12:24:12 AM
Juice
Status: offline
In a rush during my lunch hour, I bought the Heli blend when I should have bought the 4-stroke blend.
On the Cool Power Blends website, the two blends have the same numbers. That is:
Blend .................. Nitro Lube Viscosity
15% (standard Heli) 15% 17% Ultra-High
4-Stroke (standard) 15% 17% Ultra-High
The questions are... Is there actually any difference in the two blends? Can I use the Heli blend on my 4-stroke airplane engine? Or should I go back to the LHS and exchange the Heli blend for the 4-stroke blend.
Juice
       Post #: 1
RE: CoolPower 15% Heli vs CoolPower 15% 4-stroke - 5/6/2008 12:53:24 AM
XJet
Status: offline
I wouldn't use either in a 4-stroke that I liked.
They use a fully-synthetic package of relatively low-tech oil.
This means you run the risk of bearing corrosion/failure and higher wear levels than you'd get with a more suitable fuel.
If you value your 4-stroke engine, look for a fuel that has at least a small (3%-4%) of castor in it and preferably a hi-tech synthetic such as one of the European brands (Motul, Aerosynth/Aerosave, etc) or (in the USA) Coopers.
Your 4-stroke will run just fine on Coolpower fuels and indeed many people use Coolpower without any problems but there are a *lot* of folks who have discovered that this stuff will not protect your bearings, lifters or camshaft anywhere near as something with a better quality oil and/or a little castor in it.
_____________________________
When I'm not here, I'm at RCModelReviews
(in reply to Juice)
       Post #: 2
RE: CoolPower 15% Heli vs CoolPower 15% 4-stroke - 5/6/2008 3:07:41 AM
mpalermo
Status: offline
AMEN!!!!!!!
Could not have said it better myself!!!
(in reply to XJet)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
