Enya SS25 over heats & quits
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> Enya SS25 over heats & quits
Page: [1]
Login
Enya SS25 over heats & quits - 5/6/2008 4:43:18 AM
Crazy4Flight
Status: offline
I got this Enya SS 25 on a swap meet SIG Wonder.
with 15% nitro fuel running rich launch and with in a minute it quits
has good idle and transition but go wide open its done
head bolts, front plate, and carb screws tight.
any fix it ideas or sell it on ebarf for junk value. ??
       Post #: 1
RE: Enya SS25 over heats & quits - 5/6/2008 4:53:10 AM
Fxrs_tim
Status: offline
Check your tank and lines for even the slightest pinhole. Also, vibration may be causing the fuel to foam which is leading to lean runs. I've gone to bladder tanks on all my non-pumped engines and haven't had any issues since switching.
Tim
(in reply to Crazy4Flight)
       Post #: 2
RE: Enya SS25 over heats & quits - 5/6/2008 5:47:51 AM
combatpigg
Status: online
What size prop are you running? 9x4 or 8x5, .25s can be pretty picky.
_____________________________
Led Zeppelin is NOT "old fogie" music.
(in reply to Fxrs_tim)
       Post #: 3
RE: Enya SS25 over heats & quits - 5/6/2008 8:00:38 PM
stg61abc
Status: offline
Hi, test the engine with another plug. Also, its a good idea to check if the o ring below the carb is in good condition. another hunch. check if you are feeding the engine with the correct line, the clunk one, not the vented one.... happens to me 2 times hehehehe....
junk, Enyas???? Nooo, they are great engines!!
cheers
< Message edited by stg61abc -- 5/6/2008 8:02:49 PM >
       Post #: 4
RE: Enya SS25 over heats & quits - 5/6/2008 8:55:22 PM
evan-RCU
Status: offline
While some people like the Enyas, I would never have one.. or a K&B... there are alot of good motors out there why put yourself through the stress?
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
(in reply to stg61abc)
       Post #: 5
RE: Enya SS25 over heats & quits - 5/7/2008 1:29:52 AM
combatpigg
Status: online
Some plain bearing engines suffer from a runaway heat problem from too tight of a crank fit. Sink cleanser powder mixed into a paste with oil is a good lapping compound to relieve a tight fit..
The symptoms are similar to a bad fuel delivery, the run starts out slightly rich and all is well, then the engine starts sagging 1/2 way into the tank.
< Message edited by combatpigg -- 5/7/2008 1:34:12 AM >
(in reply to evan-RCU)
       Post #: 6
RE: Enya SS25 over heats & quits - 5/7/2008 2:28:01 AM
tucker1865
Status: offline
The Enya 25SS has a steel liner, cast iron piston and dual ball bearings. Treat the engine as new and do the proper break-in. Very rich setting (4 cycling) for a couple of tanks, then just into 2 cycle and back and forth between 2 and 4 cycling for another couple of tanks. Leave the glow ignitor on for the first 2 or 3 tanks. Then start to lean it a bit and heat cycle the engine. Run it a minute, shut off and cool. It will take at least an hour of running to be broken in, according the instructions. This is not an ABC engine and should be broken in like a ringed engine. After at least an hour of running, run it pretty rich and fly it for 3 or 4 more tanks and lean it a little each time. Then evaluate it. If done properly it will last as long as you will. I have heard that you will leave it to your grandchildren. (quote from "downunder" ) Look up his postings and you will find the proper break-in. Most people do not have the patience to properly break-in ring or cast iron piston Enyas. You are probably running too lean too early.
< Message edited by tucker1865 -- 5/7/2008 2:29:26 AM >
(in reply to combatpigg)
       Post #: 7
RE: Enya SS25 over heats & quits - 5/7/2008 3:35:01 PM
bob27s
Status: offline
Run the crud out of it, under-prop it for about the first 20 minutes.
The flight situation might be foam occuring sometime during flight.
You can find out if that is the case by going up in prop one size and trying again (key here is just changing the rpm peak).
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
       Post #: 8
RE: Enya SS25 over heats & quits - 5/7/2008 10:21:29 PM
Crazy4Flight
Status: offline
it is NOT a new engine, compression is average, it is well past the break in period.
(in reply to bob27s)
       Post #: 9
RE: Enya SS25 over heats & quits - 5/8/2008 1:32:18 AM
combatpigg
Status: online
There are the basic "feel" tests for cylinder leak down and how well the crank turns that I assume this engine has passed. Also assuming that it isn't all varnished up. The iron/steel engines benefit from castor oil in the fuel. The Castor allows running closer to peak without overheating, but it leaves a varnish build up sometimes. I use Hoppes #9 gun cleaner and a gun cleaning kit to remove varnish. Don't disturb the liner, just clean as much as you can with just the head and backplate off.
Do like Bob27 says and try a 7x6 on it if the engine is mechanically sound.
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.595RCU1
