Merlin Man
Joined: 2/18/2004 From: Coffs Harbour, , AUSTRALIA Status: offline
Hi, I don't know if I am missing something here, but, with a foam wing , can't you angle the retract bodies as you want? Can't you adjust the forward rake and dihedral angle whatever the retract units you choose, by positioning the retract support timber as you want it ? I understand that determining these angles may not be all that easy, and then transferring these angles to the wing itself wouldn't be that easy either, but I am sure it can be done . Trial and error on a mock up would help. Just my 2 cents worth. Cheers, MM
