rlmcnii
Joined: 7/3/2005 From: Pocomoke City, MD, USA Status: online
airbusdrivr, I have a Flyin' King with a Saito .91 in it. The .91 is more than sufficiently powerful for that airframe. It is rarely run, in level flight, at more than half throttle. With flaps take of run is about ten or fifteen feet, and that is in grass. The Saito 1.20 would be a nice engine for that plane, if you like a lot of excess power. You will probably have to install the batteries aft to balance it, no trouble. The airframe will not notice the weight and you will probably have unlimited vertical. You will also need to master the use of the throttle, but it sounds as if you already have. Flyin' Kings are fun low and slow with partial flaps, an engine with good low-speed torque (the 1.20), and a low-pitch, large diameter propeller. The more you fly it the more fun you will have. I like to hang mine on the prop (nose up) with half-flaps, put in a full rudder deflection and watch it yaw around the propeller. I call it Flyin' King 3-D. Have fun with yours. For $150 it would be hard to go wrong with that engine.
