Mr. Mugen
MI, USA Status: offline
Aerorecon....you won't be disappointed if you get one. They are worth the extra 20 bucks over the Eflite. I had several eflite six series motors and they rock but the mega is a smokin set up. I had mine hitting 138 this winter with a 4s 3850 V2 TP pack, CC125 esc, heat sink (not needed but used anyway), 6mm gold connectors, 2 hs-82mg servo's (next plane will have different servos....these developed slop rather quickly), CC BEC, MedUsa Opto isolator, and a 2.4 Fasst rx. She screams like mad. Drawing around 92A cont on a 6.5x6 with outside temps at 10 above F. Kevin
_____________________________
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
